What tire would be better
http://209.85.207.104/search?q=cache...nk&cd=20&gl=us
Ted
Unfortunately do not have a big choice. The only reliable brands are: Michelin, Dunloop, Continental, the rest is Chinese **** =(
I like the Toyo T1-R the best out of the mentioned ones. It rides quieter and grips better.
At the track, the best 60ft times I was able to pull was 1.8!! This is while running NT555 or T1-R.
https://mbworld.org/forums/wheels-tires-suspension-brakes-forum/68013-tires-ones-best-revised-03-25-2011-a.html
Welcome to mbw.
Ted
Ted
Andrew
The non-directional tread design was quite extraordinary and the tires appeared stout!
Just like any other Nittos, the cross profile is a bit square so be careful when choosing the width.
The dealer said that the inner face of my front tires MIGHT rub against the fender liners when turning the wheels all the way, so they asked me if I wanted to raise the front coilovers by 1/8” just to be on the safe side.
But I wasn’t too concerned because the fender liners are somewhat flexible and relatively soft.
And if they indeed rub, it only happens when turning the wheels all the way, which I will never do.
And even if I need to do that, it won’t be for a long time or at a high speed.
I’ve had 60 miles on them, 50% highway, 50% city streets full of bumps, manhole covers, patched asphalt, and I didn’t have any problems.
No vibrations, no rubbing, and no wiggling on grooved pavement. They’re sticky, have good grips and I was impressed by the noise level. Very quiet.
Front: 235/35/19 on 19x8.5
Rear: 255/35/19 on 19x9.5
H&R coilovers, + spring pad #3 on the rears.
