What tire would be better
Old Feb 8, 2006 | 12:10 PM
rockgt302's Avatar
2005 C55 AMG
Im putting 19" wheels on next month. Its either Nitto 555 extreme or Toyo T1R. Which is a better tire and would less likely rub?
TIA
Old Feb 8, 2006 | 02:07 PM
Vomit's Avatar
2002 C32 Black/Charcoal
I think the Toyo has less rubbing issues, because of a more rounded profile (or maybe this only applied to the T1-s?).
Old Feb 8, 2006 | 03:55 PM
CLKBSVegas's Avatar
a Black
I actually think both tires are quite round. I have run the Nito555s and they are rounded and I currently have the Toyo T1-S (which I think are the prior version of the "R"s). Not having both to look at together...I think the Nitos are more round.
Old Mar 28, 2008 | 08:58 AM
bud4ya's Avatar
2003 C32 AMG, 2003 E39 M5
I know this is an old post on tires
but I am trying decide what to get and not spend a fortune. For the price I was thinking either the T1R's which will cost me $600 or the Nitto 555's for about $480.
I also looked at the 050 but my tire guy said you will be lucky to get 6-8 thousand miles.
I have owned many sets of the T1R's and they were great. But if I can save a couple $100 for the same kind of tire 555's then I will do that. I want grip, handling and not noisey.
I am looking at 255-40-17 and 235-45-17 going on a C32
I know this tire subject is like just do not want to cheap out over a couple hundred and not be happy.
Old Mar 28, 2008 | 11:18 AM
MRAMG1's Avatar
S600, GL450, GLC 43
I'm not sold on this, but I'll let you knoiw as I have them all the way around and LOVE them. They have been the stickiest street tire I have EVER owned.
Longevity was not an issue for me, FUN was.
See yeah
Old Mar 28, 2008 | 01:49 PM
360_iti's Avatar
W203, W211, W219, W212
I currently have about 38,000 miles on my NT555s with 3/32” left.
So they last quite a while, but they will give you a lot of noise for sure and I was sick of it. Then I decided to purchase a set of Nitto Invos for my summer, and according to the reviews I’ve read, they have excellent handling in wet and dry, very quiet and the pattern looks awesome. Still waiting to receive them.
Old Mar 28, 2008 | 02:57 PM
F1ferrari's Avatar
'05 C55 AMG
I had the NT555s on an 01 acura 3.2cl type s...I had to change at least two wheels(thank god i paid for that warranty) every 3 months because of impact bubbles. I'll never by a nitto again. Try Michelin, Dunlop, or Bridgestone.
Old Mar 28, 2008 | 03:54 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
$480 for 19" ...go for it. can't beat that price doesn't matter what tire that is.
if you are spending $600 you can check out the Hankook K104 as well. IMO they perform better than the T1-R although a little bit noisier.
Old Mar 28, 2008 | 03:58 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
how much did you get the INVOS for? I saw the pricing on tires.com, but they always have higher price than other places.
Old Mar 28, 2008 | 04:20 PM
360_iti's Avatar
The best deal would be on ebay, from discount tire direct.
$173 for 235/35/19 and $209 each for 255/35/19, + free s/h
Old Mar 28, 2008 | 04:56 PM
bud4ya's Avatar
http://www.1stoptireshop.com/html/etailers.htm
Try this linky
Old Mar 30, 2008 | 06:34 PM
bud4ya's Avatar
Have you got the Invo's in yet? Have you tried them out if you did get them? Trying to decide on a tire now. It was the Nitto 555 till I heard the noise issues with them.
Old Mar 30, 2008 | 11:31 PM
360_iti's Avatar
I got the 2 front tires last Friday, and the rears should be here on Wednesday. Don't know why it took so long to deliver.
I don't think I'll be able to give you an accurate review since new tires are basically good when you first try them. The noise on NT555 didn't come out until about 12-15k miles, and it was unbearable. If you go to their website and compare the two, you'll see that the invo has better ratings on everything.
http://www.nittotire.com/#index%2Efeature%2Estreet
Old Mar 31, 2008 | 12:11 AM
flush's Avatar
2003 C32
I've clocked 8k miles on Nitto Invos on stock 17" rims. They are now louder than the Michelin Pilot A/S they replaced. Went to a track day with them with barely 1000 miles on them and things were drastically different after, sigh, ah well.
Will look for different tires next change, probably Goodyear F1's next.
Old Mar 31, 2008 | 12:13 AM
e1000's Avatar
a quarter mile at a time
I've got NT555's on right now and although they're not terrible, I'm pretty sure I'm going to replace them with something else. The rears are worn down to the wear bars and the fronts are almost completely gone too. Maybe I wore them well but excessive noise hasn't been an issue and I don't hear them above my radio or anything. I could be wrong but the side profile of them seem a bit squared to me, not rounded.
Old Mar 31, 2008 | 01:08 AM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
My brother has the toyo T1R's on 19X10.5 inch work wheels and those tires are killer. they look good and track well. he has them on a G35 coupe lowered and they rub abit in the back but that's because his suspension needs to be adjusted.
Old Mar 31, 2008 | 01:22 AM
Ted Baldwin's Avatar
300ce
.........consider General Exclaim UHP. Not pricey but performs very well. Less expensive than Toyo's and NT555's. I believe the NT555's and the T1R's are the same tires but branded differently. You can compare the EXclaim UHP to other more expensive tires at tirerack.com.
Ted
Old Mar 31, 2008 | 01:34 AM
calimax's Avatar
RENNtech C32 AMG
I have the Nitto 555 on the front and the side edges have worn down quite a bit and are getting nearly smooth. I've had them on for about 6k. Defiantly spirited driving, but not carving the corners like I do in the c230 loaner car!
Old Mar 31, 2008 | 07:44 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the T1-R doesn't perform nearly as well as the T1-S it replaced. They made too much compromise to make the T1-R quiet because the T1-S were incredibly noisy.
Old Mar 31, 2008 | 07:49 PM
c3232c's Avatar
02 c32 99 superduty
Had a set of 555's on my 99 Kompressor, Good sticky tire but thats about it.
e1000's Avatar
No.
Old Mar 31, 2008 | 11:25 PM
lizardjack's Avatar
Shelby GT500
M... Do not have much choice here. Just about to buy Michelin PS2. Do they worth the money they cost?
C32 owner
Old Apr 1, 2008 | 11:00 AM
360_iti's Avatar
My .02: depends on the size. 17? Might be worth it. 19" would be too expensive. I just can't justify spending $350 on one tire.
Another thing, do you need to use winter tires as well? If yes, then save your money.
Old Apr 1, 2008 | 11:13 AM
c32used's Avatar
LET C32 2002
+1
Old Apr 1, 2008 | 02:27 PM
MRAMG1's Avatar
S600, GL450, GLC 43
C32 owner
In a word "NO"
Check my other post for more info, as this has been
see yeah
