SLK32/C32 diff issues...
C43, SLK32, CLK63 Black Series
Cross posting from benzworld R170 forum where a reader with a modified SLK32 discovered a problem with his diff when going to install a Kleemann LSD. I thought it was relevant to this forum as well. It would be interesting to know how common this problem is.
http://www.benzworld.org/forums/foru...id=26#M1787979
Former Vendor of MBWorld
Originally Posted by smgC32
That should happen to any open diff car that builds excessive heat due to extended happy driving!
Are you saying that this would never happen in a low hp/tq car doing smoking burnouts or constant drifting/power sliding? I believe the reference with the SLK owners has to do with powersliding more than burnouts. Ever see the posted vid with the SLK sliding around a constant radius? Or the other car (C or E Class) in a parking lot doing figure eights with light poles as obsticles? Once the car's rear end is hung out, the amount of hp/tq to hold it in a slide is not that great. In therory, if you could hold a slide for hours around a skid pad in a low hp/tq open diff car, the diff would fail, not because of power output, but due to excessive heat buildup. The stronger the diff assembly, the harder it is to break. The weak link I believe is the bushings that surround the shaft in question and that they can't take the heat. We really need to see the other components of that car's diff. Any pics?
When this problem is ignored, this is what will happen:
I thought there was a bushing that seperated the gear and the shaft. If this was to fail, you would have wear on the shaft similar to what you would find on a crank after spinning a crank shaft bearing. In your pic, did the shaft extend far from its hole or just elongate it and the wear was at the point of insertion in the housing? The previous pics from the other forum show wear an inch or so from the ends where the gear fit onto. Does the gear fit onto the shaft metal to metal? Is that a pic of a SLK diff? It appears to be different than the C32's core. I have had my ECU shut down the car before due to high diff temps caused by excessive wheel spin with the open diff design. Any more pics of an SLK diff to compare to the C32's in order to varify compatibility?
There is not any kind of temperature sensor, or any other sensor for that matter in the differential of MB cars, so how can your ECU possibly cut timing/throttle, etc. without at LEAST a temperature input signal from the Diff? The answer is simple- it can't. Are you talking about something other than an MB? Your car shutting down was not caused by Differential overheating. I can do big nasty burn outs in my CLK for hours on end without anything "shutting down"- sounds like you have some other issue if your talking about your C32. Probably excessive inlet temperatures, coupled with high intercooler water temps, due to virtually no airflow and high engine revs- just my .02
You may me more knowledgable than me in this arena, and your experience with Kleemann's assembly observations surely show what goes wrong. I am curious how the gears are held together without a bushing and how they don't overheat, metal on metal.
If you are doing hours of burn outs, is this a picture of your diff that broke or is yours OK?
As for overheating and shuting down the ECU, I additionally have heat soak issues with the supercharger that probably can only be solved by manufacturing a custom intercooler that sits on top of the supercharger. The current location of the intercooler prevents heat dissapation at appropriate rates. I feel though that the stock exchanger in the front of the car is more than adequate and twice as large as the one offered by the other company that is getting so much press in another thread at this time.
amg, bushing, c32, diff, differential, end, fluctuations, heat, modification, problem, problems, rear, slk32, soak, temperature
