need to buy 4 new tires
Old Aug 11, 2002 | 05:05 PM
bonyhadi's Avatar
C32 and CLK430
Post need to buy 4 new tires
Hello guys,
Got about 25K of pretty much trouble free driving (some computer issues) on my C32. Don't want
to change the wheels. What is the biggest tire I can slip on without clearance issues? Also what
brands to you gents recommend? I drive in sunny California, some rain, zero snow. Thanks for
your advise.
Old Aug 11, 2002 | 05:35 PM
ryson's Avatar
2014 E350, 2008 C300 Sport
I'd post a thread for Luke at Tirerack in the wheel forum. But as for brands, I'm looking into Yokohama AVSdb. Being in CA as well, my main concern is tire noise.
Old Aug 11, 2002 | 06:04 PM
JustinTRW's Avatar
C32 AMG
On a related note, please look at this thread:
https://mbworld.org/forums/showthrea...threadid=14376
Old Aug 11, 2002 | 10:48 PM
C32AMG-TW's Avatar
E55AMG, Smart
I prefer P-Zero Rosso than Michllin Polit sport.
Old Aug 12, 2002 | 07:06 AM
Ice 9's Avatar
Second that. I have heard rave reviews about the P-Zeros
Old Aug 12, 2002 | 12:42 PM
Harris's Avatar
I've used up 1 set of regular PZeros and 2 sets of PZero Rosso. The good thing about it is they stick like a glue on the road. BUT I just cant stand that they wear out too fast, I've to change them every 6000 miles! I am using Toyo T1-S which I like it VERY MUCH!! A lot of ppl are saying S-03 are good, but cant comment on it cause they dont make my tire sizes.
Old Aug 12, 2002 | 10:49 PM
bonyhadi's Avatar
C32 and CLK430
Thanks for your replies. Anybody run Kuhmo's? Looks like I will get 28K on my Michlein
Pilot Sports that came with the car. Guess that is pretty typical?
Old Aug 12, 2002 | 11:56 PM
rrf's Avatar
rrf
Pirelli, Pilots, Toyo
There is something amiss here: Harris gets 6000 on Pirellis, you get 25000 plus on Pilots. I'll get maybe 15000 on the Pilots.
So maybe these opinions are more a reflection of drivers than tires.
Your driving and mine and Harris's are all different.
I suggest you look hard at the Tire survey at Tirerack.com.
http://www.tirerack.com/tires/surveyresults/max.jsp
You should be fine with any of the mentioned tires, but the Michelins will probably last a wee bit longer and should handle comparably. On the average car with the average driver.
You have to choose what you are willing to trade for what other feature. If you want them to last 25000 mi and you are happy with the handling then why look further than the Michelins?
The tire rack survey does say that the Pirellis will last a LITTLE less, but doesn't say they actually handle better wet or dry.
So you can believe people that have put 2,000,000 miles on the above mentioned tires on OTHER cars or the few that have them on a C32 just like yours.
Seems the Pirellis on the C32 are very popular no doubt though.
That cannot be ignored.
Toyos T1-S are good tires and worth a look, I have then on a different car and I like them. Less cash and better wear than even the Pilots.
In any case, study the survey before you buy.
Good Luck!
Old Aug 13, 2002 | 12:43 AM
Kar don's Avatar
Mercedes-Benz
woah, my IS300 has bridgestone potenza RE040s, @ 7200 miles im about 50% tread left. Damn performance tires.
Old Aug 13, 2002 | 09:07 AM
bagwell's Avatar
From: Houston,TX-moving to The Woodlands,TX SOON!!!
Toyota Tacoma & Lexus IS250
back to the question -- anyone know what's the largest tires that will fit on the 17" OEM C32 rims ?
Old Aug 13, 2002 | 11:38 AM
JustinTRW's Avatar
C32 AMG
I know you can mount a 235/f and 255/r, but I do not know if it is recommended. I do know that the S03 tire has a wider contact patch than either the Pirellis or Michelins for the same size tire. Just a difference in manufacturing I guess.
Go with wider fronts and keep the rears the same...it will solve understeer Otherwise, get new rims and widen everything.
Old Aug 30, 2002 | 01:32 PM
rrf's Avatar
rrf
__________________
You can put 245/40 on the front and clear the fender and strut. But then you are pushing the 7.5 rim well past its recommended max tire width limit. Note that 8.5 OEM rim can fit the front, BUT IT IS VERY CLOSE. The 8.5 OEM would be a better sized rim if you wanted to put all the rubber you could on the front.
But with Stk 7.5 front.......Suggested is max 235/45 on the 7.5, even going to 235/40 is not recommended on the 7.5.
On the rear you should also stay within the limitations of the rim width (not just the wheel-well width) So looks like 255 is OK for the stk 8.5. Ditto 265 would be pressing the envelope, for 8.5.
If you exceed the recommended range of the tire width to the wheel width cornering/handling will be adversely affected.
Note MKB has 245/40/18 in front, and and 265/35/18 in rear
So those sizes will certainly fit the wheel wells, but those are not on the stk AMG rims. The numbers show that car can handle better than the typical C32.
