Service Campaign 2006-030011
C32 AMG RENNTech
Received the notice yesterday. They would like us to bring in the C-Class cars for a software upgrade to the ECU to correct a false "check engine light" warning due to a secondary air injection pump relay.
I have a C32 AMG with RENNTech ECU upgrade. I was wondering if the software upgrade with adversely impact the RENNTech code?
Do any of you have any experience with this or some information to share?
I plan on calling RENNTech tomorrow to get their input as well.
KP
KP
i would talk to renntech, but i would think that having the dealer reflash your computer would erase anything that renntech has done...usually only your tuner can answer that question
C32 AMG
I talked to my service advisor. He told me they only updated part of the ECU, not the performance parameters. So my chip should not be erased. I still have to check with my tuner to make sure.
C32 AMG RENNTech
I will call RENNTech tomorrow and post their response about the MB dealer ECU reprogram and it's impact on thier performance ugrades. If the reprogram will impact the mods I'll likely hold off on getting the car to the dealer, since there is no problem.
In the interim, if anyone has been through a MB recall impacting ECU programming and have aftermarket ECU upgrades, please share your experience.
KP
KP
2002 C32 Black/Charcoal
Originally Posted by Zeppelin
I don't plan on taking my car in for this mod. Just unplug the air pump and problem solved.
Any downside to doing this? Where is the connection to unplug?
Originally Posted by Vomit
Zepp:
2003 C32
sheesh, don't you guys read any other subforums?
https://mbworld.org/forums/w211-amg/145219-service-campaign-2006-030011-info-people-upgraded-ecu.html
C32 AMG RENNTech
Thanks for adding the link from the other thread.
I spoke to RENNTech today, and they suggested either putting off the service if there is no current problem, but be aware that they will reflash the eprom if you go in for other work, or getting the recall done and then sending them the ECU for reprogramming at RENNTech. They will reprogram at no charge, our cost would be shipping both ways.
2006 E55
does this have anything to do with the air pump failure thats happened to people in the past. Havent had a single problem yet (knock on wood)
Silver 2002 C32, Silver 2006 CLK 350
yes I had this done Friday. they told me that that pump dont need to run all the time, only when you start your car. They did this because they had to replace a lot of secondary air pumps on warranty and MBUSA is saving money by just Flashing the ECU making the pump run less than replacing that $400 pump.
C32 AMG
Coincidence or What
Last week I start noticing that after short bursts, sometimes after some minutes cruising at the highway, pushing the car to make a pass and the revs would just go up with little power to the wheels. Like no supercharger. Then waiting extra minutes and the supercharger/power comes back.
Could it be related to this recall or whatever fancy name MB wants to call it?
Thanks!
Ricardo.
Thanks!
Ricardo.
Thanks!
Ricardo.
Thanks!
Ricardo.
C32 AMG
Originally Posted by Trekman
No it does not have anything to do the supercharger. your intercooler pump might not be working. this recall is for the Smog pump or secondary pump programing that makes the pump run even when not needed.
