94k miles on same brake pads, possible?
How many miles have yon gone with your pads?
Put Akebono pads on W210 and at the time of selling, I had about 140k on them. Measured to still have over 60% pads wear left, so they would make 400,000 miles would I keep the car that long.
Than my stepmom seldom makes 20k miles on pads.
When for me - using a brake during normal driving is driver error, she drives with her left foot over brake pedal all the time and following her you can see the lights coming on every few seconds.
Also I use tolls, instead of riding with the local plebs. Around here is a mosh party I rather avoid.
, keep my distance from other cars
and let go of the gas to keep the distance, (similar to @S. Madman ).After the Italian tune-up, I can hear the exhaust hot
, but no smell from the brakes Last edited by JCM_MB; Nov 3, 2022 at 02:08 PM.
Than retiring to Las Vegas, I bought 250 Bluetec, who has daily mpg meter on the cluster.
So even I still don't like to just roll, my goal most of the time is to make the trip averaging above 40 mpg. Amazingly by comparing, slowing down a bit, can add 1 minute to 20 minutes trip, but I can drive several streets and make several turns without touching brake pedal. Las Vegas has wide streets, so I can make wide turns, so that might not be possible in other places. The only disadvantage to cornering without braking are tires rounding the corners,
beware that inner and outer pad on each wheel do not wear equally.
The piston-side pad on the inside does most of the wearing. The outer-side pad doesn't do much due to heavy caliper spring preventing caliper sliding (regardless of lubed slides).
You'll love your Japanese Akebonos !
Driving up and down California hills I managed 60kMi - Fairly satified with OEM TRW pads and OEM Brembo disks.
I replaced fronts with Zimmers + Akebono
and rear Akenono on mint disks as-is, no machining/replacement needed.
> Easy fixin' :
The three factory issues were...
-1- the 8x dry caliper slides
-2- the 4x heavy caliper-springs preventing floating caliper from self-centering (assimetrical wear).
-3- the pad-spring on the rear inners pad causing the pad to torque the piston sideways.
Meaning don't delay your simple brake job too long, you'll get excellent brakes better than factory new.
super strong super touchy super cheap
My truck has 190k miles on original brakes, it also has a exhaust brake (variable vane turbo) which helps. Wish our cars had these would be pretty cool (on the diesels atleast).
All this has resulted in very low breakwear, and higher mileage results on the tires.
While I am conducting all these operations, I snicker at all the brake riders, and wish them luck on their next brake pad change.
Oddly enough I don’t consider myself to be a defensive driver, although I must admit I am far from the most aggressive driver on the road.
