C55 Bixenon beam not pointing high enough
Old May 28, 2006 | 12:26 AM
cntlaw's Avatar
C55AMG W203; 330i E90
C55 Bixenon beam not pointing high enough, wonder if anyone experienced this possible Auto Levelling issue?
thks
Old May 28, 2006 | 10:34 PM
rlee02135's Avatar
2004 C32 ///AMG
adjust it manually.
there is a 13mm nut on top of them.
Old May 28, 2006 | 11:23 PM
cntlaw's Avatar
many thanks, I am a total idiot of headlamps engineeering, sound complicated if I have to open the lens and dont know which is the right level ? i thought auto-level si supposed to be functional and not sure what is the adverse effect if it is adjusted manually.
Old May 28, 2006 | 11:28 PM
rlee02135's Avatar
2004 C32 ///AMG
park 25 ft away from a wall on a level surface and turn the nut right on top of the headlamp.
no need to oped up the headlamp, just the hood.
Old May 29, 2006 | 01:42 PM
CynCarvin32's Avatar
Mercedes Benz
Originally Posted by rlee02135
adjust it manually.
You should check the swaybat mount for the auto-level first. If I remember cnt did some suspension work recently? Even if not the lights level is set by the front swaybar mount and a sensor on the passenger rear lower control arm. It determines the angle of the body and adjusts the lights accordingly.
I had issues whenever my car was worked on for warranty suspension work or for having the modified suspension installed. They always seemed to forget to re-position the sensor after they finished the job.
The knobs ontop of the lights should be a last resort and are more for fixing the left right allignment.
