Brake wear indicator light..
Old Jul 20, 2006 | 11:40 PM
pointman's Avatar
a car that can't do the throttle reset.
if I remove the sensor from the pad, will the light go out? Thanks.
Old Jul 20, 2006 | 11:46 PM
Bif powell's Avatar
2002 c32
It should right? - I mean it's basically just two wires going to the rotor and when they wear enough that both of them touch, it closes a circuit and the light comes on. I would also think that there would be no reset procedure when the computer thinks you put a new sensor in. You should wait for someone more qualified than myself to give you and answer, but having just done a brake job, I infer that's how it works.
Old Jul 20, 2006 | 11:58 PM
pointman's Avatar
thanks. appreciate the input. i ask, cause on the front end i have a sensor.. and on the rear i dont have one right now. and the light is coming on sometimes.. so i am trying to figure out what is causing the light. I am not sure cause both ends needs pads.
Old Jul 21, 2006 | 09:25 AM
silver_metallic's Avatar
2016 C63S,2013 C63 AMG Coupe, 2002 C32 AMG (gone but not forgotten)
You've got wires touching somewhere, perhaps a short in one of the sensors, or frayed wires prior to one of the sensors. You could always disconnect all the sensors or just get 4 new ones when you buy new pads.
I would get new sensors. Cheaper to replace pads than it is to replace rotors.
Old Jul 21, 2006 | 03:47 PM
pointman's Avatar
awesome! thanks for the info. thats exactly what i needed to know. thanks!
