Does anyone have an ASP pulley + ECU Flash
Rating: Thread Rating: 19 votes, 5.00 average.
Old Jul 29, 2006 | 11:10 AM
PBenz32's Avatar
2003 Pewter C32
Hey just wondering if anyone dynoed their car with these mods? Is the hp gain almost equal to EvoSport. Is the ECU flash worth it, once you have the pulley? Which chip gives the most gain Renntech, Kleeman, Powerchip...
Thanks Pete
Old Jul 29, 2006 | 12:00 PM
jgsx's Avatar
04 C32
I went with the ASP pulley, and am using a stage 2 Powerchip. I don't have dyno info yet
Old Jul 29, 2006 | 12:18 PM
PBenz32's Avatar
2003 Pewter C32
Did you do both mods at the same time or did you get the pulley first, then the ecu flash. If so did you notice a lot of gain. I am gearing towards the asp also because of my car is still under warranty.
Thanks Pete
Old Jul 29, 2006 | 12:36 PM
jgsx's Avatar
04 C32
I did the full stage 2 all at once, so I don't know what did what
Old Jul 29, 2006 | 01:22 PM
amgmark's Avatar
ML63
What do you mean by stage 2? Stage 2 software? or Stage 2 kit with headers etc.. ? Just wondering..
Old Jul 29, 2006 | 04:39 PM
jgsx's Avatar
04 C32
ASP pulleys, SL55 intake splitter, evosport headers, evosport intake spacers, powerchip for stage 2
Old Jul 29, 2006 | 04:44 PM
mig888's Avatar
EVE
NICE joe - probably gonna pull the audis and m3s all over the place - btw you didnt get the whole SL55 engine cover from those part #s right?
flip
Old Jul 29, 2006 | 05:30 PM
jgsx's Avatar
04 C32
flip
I didn't do the full SL55 swap. All I used was the SL55 splitter with the two pipes. I got them from evosport, so they were already modified to fit right onto my stock airboxes. Since I kept the stock airboxes, I didn't need to modify the engine cover. You can easily modify the stock SL55 pipes yourself
Old Jul 30, 2006 | 10:14 PM
Eurocharged Rick's Avatar
SPONSOR
do you plan on dynoing your car or taking it to the track anytime soon? i am curious to see what kind of power it is putting out...
Old Jul 30, 2006 | 10:27 PM
jgsx's Avatar
04 C32
I'm going to dyno it in a couple weeks. I'm about to move, so I'm short on time right now
Old Sep 22, 2006 | 10:31 PM
Rudoubles's Avatar
03 C32
I'm looking into some pulleys & an ECU flash sometime soon. Does anyone know if it matters if you have pulleys and no ECU re-flash, or would it be better to get the ECU done first, and then pulleys? I'm kind of just learning about this stuff. Has anyone had their ECU reflashed by Speed-Innovation? How satisfied are people with their ASP pulleys?
Old Sep 24, 2006 | 12:03 AM
SPONSOR
get the pulleys first...very satisfied with the ASP pulleys...
Old Sep 24, 2006 | 02:13 AM
pshek's Avatar
2003 C-Class Sportcoupe
Have you ASP pulley guys experienced louder belt noise at idle? I heard a C32 idling with the evosport undampened pullies and the idle noise from the belt was obnoxiously louder than stock. The noise made me kind of worried...
Old Sep 24, 2006 | 08:00 AM
SPONSOR
i don't have any louder belt noise...
Old Sep 24, 2006 | 10:35 AM
jgsx's Avatar
04 C32
No noise here
Old Sep 24, 2006 | 12:51 PM
pshek's Avatar
Going for the ASP pulley....
I guess that settles it then, I'm going to get the ASP pulley which is a stock pulley with a ring welded onto it, retaining the factory harmonic balancer. I was afraid the undampened evo pulley was the cause of the excess belt noise. So I will only get a dampened pulley. I couldn't find the pulley for the C32 on ASP's website. Any helpful info on pricing, etc?
Old Sep 24, 2006 | 05:23 PM
m444's Avatar
Audi C7.5 S6
The website is a little flaky, so are many others, navigation does not always work correctly. At one time there was a webpage for this asp pulley, but you had to use the search to find it. Send an email from the website or call them.
asp@aspracing.com
The ASP pulley for the C32, ""PN 331380 is $ 970.00 for a harmonic dampner reworked to 14% overdrive or a dia of 6.810 inches. The kit also includes the water pump pulley and idler pulley. These allow the kit to retain the factory belt.""
Old Sep 24, 2006 | 11:25 PM
ellery's Avatar
2003 C32 AMG BLACK
i'm also curious to know what this setup is putting down...
What is this I hear about ASP Pulleys not voiding the warranty? Is that really the case?
Old Sep 24, 2006 | 11:29 PM
SPONSOR
they can still void the warranty, but are less likely to do so because they look fairly close to stock...it just depends on the stealership
Old Sep 24, 2006 | 11:39 PM
jgsx's Avatar
04 C32
A tech has to know the C32 very well to notice that the ASP pully is aftermarket, since it is a modified stock part. The other pulleys scream for attention, so are much more likeley to cause trouble with the dealer
Old Sep 25, 2006 | 03:16 AM
KompressorKev's Avatar
'14 428i M-Sport, '02 C32 AMG
i have asp's - no noticable noise during idle, but yes i believe a mechanic will be able to detect them, due to the weld. while some may not notice it, it's not 100% stealth, so i would not consider this a warranty advantage over other brands.
You have already rated this thread Rating: Thread Rating: 19 votes, 5.00 average.
