Does Anybody know a good Mercedes Chip/ECU/TCU programmer?
. In addition to the ECU this person must also be able to reprogram the Tranny Control Unit to minimize drivetrain loss and transmission slippage. The compensation could be quite rewarding!
This is good stuff... part deux...
In fact, I heard rumors that this SC will replace the Lysholm that is currently used on the Kleemann kit. This SC has twisted rotors that form a very pronounced Helix making it even more efficient than the old twin-screw design.
Guess who is going to be the first C55 owner with this new blower? Coupled with a BONA-FIDE benz chip tuner/programmer/software engineer and a beefed up heavy duty cooling system, the Magnusson experts told me that I could be making 500+rwhp provided the ECU and TCU are tuned properly.
According to Magnusson's "Hot Rod King" as he calls himself at Magnusson, the key is to find the right programmer because even Chrysler owners are getting frustrated with the inablility to tune the new ODB/ECU that Mercedes put in all their Chrysler vehicles. In fact he told me that many Chrysler owners have switched to Ford or GM brands in order to SC their cars.
Honestly who gives a **** if the supercharger is the next best out there ... you can't freaking tune it.
The only 3 tuners(that I know) with a supercharger that (WORKS WELL) for mercedes is Carlsson, Kleemann and RT. I highly doubt your asking for those companies ...
If your still dealing with with that past company, that did your supercharger, I got to say your an IDIOT. If you talking about a new company ... my best advice would be to RUN if they don't have the programmer and are asking for your help to find one.
I hope people realize that the programmer is the most critical nowadays for the tuning of these new cars. The level of programming necessary has gotten significantly higher with all the controls the vendors have now.
What he needs to realize is that with 11:1 compression I dont care what blower you use you cant turn up the wick enough to make 500+ WRHP.
Quest to a blown motor is now on to phase #2!!
If it works more "power" to him but I would never open so many doors to large trouble and destruction. After one crappy tuner I would ship my car to Florida and just let it be done correctly.
9:1 compression, upgraded block, better cams, the works = 500+ rwhp.... Anything less is just to risky for my blood!
if I were you I would ask or do some reserch on benny's set up on his C55 or Dragons old car and go that way. Dont be a fool this guys just want your money even, if it was free if your car goes kaboom you have agreed to having them use your car as a guinea pig.
Your car ain't worth the pinkslip it's on, now that it has been whored by HPS as their official guinea pig test car. So I guess you're not removing the HPS kit anymore, huh? Did you get scared by the cost of a Kleeman kit? I kind of emphasized with your troubles before, now I know you just lack common sense.
So even if this magical blower is so amazing your motor will still end up with melted internals or a cracked block due to the fact that you are pressing it beyond what it can take.
Stop and ask yourself 1 quick question. Why does RENNtech NOT make a high boost or 500-hp+ kits for the stock C55? Well that is due to the fact that Hartmut, a man who has worked on AMG and MB's for a very long time, knows that with 11:1 compression, no modified internals, and a stock block the car can not take that kind of pressure. I think Hartmut knows the point at which a C55's block will NOT be able to take the stress. Even if you were to drop the compression on your engine you still would have a block that is far weaker than that used in all the AMG 55k motors. The AMG block is strengthened and the method in which the lower end is assembled and attached to the block is completely revised to deal with the stress of a car making 500+ hp.
So like a poster said above. Either do what you know works on the 11:1 non-upgraded C55 engine (aka Kleemann kits and RENNtech low boost kits) OR send your car to RENNtech and have the high-boost kit installed, which includes re-building the internals, lowering compression, and strengthening the block.
Did you notice that Hartmut at RENNtech told BENNYZ that he should not run a NOS kit on his car because he was asking too much of the stock engine? He felt that with time there could be real serious damage to the car. BENNY respected a man who is likely the finest in the business and removed the NOS kit.
No need for me to call some guy who makes a blower. You were impressed enough with Adam at HPS to buy his junk pile and look what you got. So here you go again buying another unknown part from some no name tuner (who never works on C55's). I thought you learned your lesson!!!
Not to be rude here but if you plan to use this car at road course events a shifty supercharger built by some no person with no understanding of the car at hand will cause you to either burn a piston your just totally destroy your motor.
Good luck with your car.
flip
Highboost kits with all the works will push out about 575-600 hp maybe a bit more if you do top mount intercoolers etc.
Why not just get a Renntech or Kleeman supercharger installed on your C55, instead of creating this science fair project?
There is a huge difference between a completely debugged supercharger upgrade and a piecemeal experiment. In the long run it would be far better to just give in and go the easy, safe and sane route.
Do you really want to
It does feel good when you stop, though.
Well try calling GIAC and see, if they are interested in a project?
http://www.giacusa.com/about.php
