Nearly Died today when wheel comes off while doing 80mph
but maybe I could develop a safe lug lock that not only prevents theft but from these hazardous situations from occuring. Thanks for the idea!
Just be glad you're alive and no one was hurt. Your entire rear axle, suspension, sway bars are probably bent, along with the other stuff. That is a lot to replace. You should ask to total the car and be done with it. Get an E55 and call it quits on the C55. Good luck trying to get MB to cover any part of the car with all the aftermarket stuff on it.
We all pay a price when we mod.
Were your aftermarket Brabus rims fake? Unless they were torqued down properly I don't see how they can just pop off even with rusted lug bolts. Unless your installer stripped the threads off of them with the "power drill." You sure they didn't torque it down to 65 ft/lbs with a proper torque wrench instead of an impact wrench. Sounds fishy.rethreading the wheel lugs due to rust doesn't even apply to 30 year old benzes - that is plain BS
greetingz,
I'm sure that I speak for the entire forum that we are all glad you are alive and well and have not sustained any major injuries.
As for the cause of the accident, the fact remains, you should find the wheel shop or manufacturer at fault and have them put out of business so that way other people will not have to suffer the same consequences. This is a civic duty you have for all of humankind and to protect yourself from another person who has the same situation who hits you and god forbid injures you or someone you know.
Take care and seriously, best of luck. It is just terribly unfortunate that you have been put in such a disagreeable situation. I sincerely hope that nobody else was injured by car body parts that you might've left behind.
Knock on wood, I hope something of this nature doesn't happen ever again.
The shop refused to acknowledge any fault even when I offered to have them pay my $500 deductible and I take care of the rest through my insurance. Now I'm going to report them to the Insurance company so they can recover through subrogation. I will also sue them for some minor personal injuries. My back and neck are starting to tighten up, my body aches and I felt drowsy this entire weekend, event during the Trojans victory. Sometimes the affects hits you later.
Either way that sucks man, glad you're ok. Do you have a picture of your car on the flatbed? I would like to see what the car looked like after it went through all that.
Ditto. Rust or no rust, it sounds like they used the wrong size lug bolts. Chrome is not a factor either. Lug bolts are so cheap, it's not worth messing around with it. Like $2 each. It's totally wrong and inexcusable if they did try to rethread the hubs. I'd have the guy who installed those wheels on a frying pan now. Don't
with them and tell them that you mean business.
Please save ALL the parts Lug Bolts and Hubs!...They will be needed !!!
Sounds like the tire shop in Question screwed up BIG TIME
The ONLY reason the hubs need to be chased/retapped is when some fool crossthreads them! Not from Rust as rust Will NOT form when a Lug Bolt is Installed into the hub...UNLESS the lug bolt is to short and some one tries to install a longer lug bolt.....Chrome lugs will NOT cause this...
Yet another reason I have a torque wrench and soft socket in the trunk...
I Request them to use a breaker bar to remove them and to HAND start the lugs then Torque with a Torque Wrench..NOT a Impact cranked up to MAX air pressure
Gotta love the tire shops with Impact on Impact off...
I will post pictures when I get back home.
