I want whiter fogs and daytime running lights
2003 C32 AMG BLACK
From the research I've done, the fogs bulbs on the c32 are 9006 (easy to find anywhere). Now, that problem is that I want the my daytime running lights to match the color of my fogs (not that stock yellowish look). Anyone konw what the bulb size for the daytime running lights?
Also does anyone know at what temperature the bi-xenon bulbs run at?
Thanks in advance
Thanks in advance
2004 C32 ///AMG
Thanks in advance
Thanks in advance
daytime running lights are 194 wedge bulbs.
If you want them to actually match, get the same brand and line of bulbs. I was trying to match 6000Ks from different vendors, and they were not even close. Carlab's 6000K looked more like 9000K+.
For your fogs, I recommend you go with an HID kit. Not only will you experience 3x more light output but you will get a perfectly matching xenon white output.
You can also replace your 194 wedge bulb with one of our sidemarker LEDs which are also 194. These are also rated at 6000k so they will be a good match for your fogs if you get 6000k down there.
2003 C32 AMG BLACK
