Exhaust Video - C32 Custom Magnaflow
When it is dry out, the car has way more traction, but when the car is about to break loose, I can feel that one wheel spins faster than the other, then traction control kicks in. I was hoping that I'd be able to gun it from a 30mph roll without traction control intervening, but unfortunately it still kills the party (even with ESP disabled).
In the rain my car is way more stable. Previously, if it was wet out, and I would give the car any sort of power, traction control would kick in. I was able to gun it at 60mph on the freeway and traction control would still come on and take away my power. That doesn't happen anymore.
Before the LSD, out of curiosity, I disabled ESP in the rain and gunned it from 5mph. My car got sideways. That doesn't happen any more either.
Today it snowed. This was the first time I drove the C32 in the snow. The car actually drove great, and I didn't have any traction issues. This was with summer PS2 tires. I don't think I would have done well without the LSD.
The car should have come with LSD from the factory. It is a great mod, but it does not solve traction issues, but it helps big time.
It so hot here still.
I left a patch of rubber about 30 yards long down the road from the house. I noticed that if you get the tires to turn and keep the gas about half throttle, and the brakes slightly applied, you can do whatever. Granted, it is not like my old E46 M3. I could be going 10 and slam it in first and pop the clutch, then do figure eights in a parking lot.
How much did you have to pay for the install? Mind sharing the info so I can get mine installed?
Limp mode got activated twice during low speed WOT pulls, and once at the top of a 3rd gear WOT pull on the highway.
I wonder if the behavior could be related to how modded your car is. For instance, the only time my car has hit the rev limiter was when I was able to rev faster than the transmission could upshift (you can make this happen on a stock C32 by downshifting into 1st at such a speed that you are only ~2000rpm or less shy of redline, then flooring it). You are tuned for performance now, so you're revving that much faster in normal WOT conditions - maybe faster than the car can compensate, even with an LSD?
I beat the car up a lot over the weekend since it was dry, and man, the car can handle SOOO much more power at low speed. With ESP on, I can't really enjoy the LSD. If the car is in a low gear, it will begin to accelerate very hard, then ESP takes away the power, then it will give it back, then take it away again. It is very jerky. With ESP off, I can finally gun the car at low speeds and actually do a full 1st/2nd gear pull. I pretty much have to turn off ESP if I want to play.
With the LSD and ESP off, the car stays pretty straight, and traction control doesn't kick nearly as often, but it still frequently kicks in and takes away the power
Here is the video.
Sorry about the video, I don't know what happened.
HEY DUDE.........NONE OF THE VIDEO LINKS R WORKING ANYMORE.
14"
18"
22"
Ihave a 2002 c32 AMG and i had a secondary cat delete. Sound is good but i want a bit more. I heard about resonator delete but i dont want to ruin the Amg sound or create raspiness and drone.
Some of you had use the magnaflow glasspack in place of the resonator. Please if you can share more details about it, it would be great and which magnaflow did you use (what size or part number)
Thx
