Replacing C32 turn signal
The problem is, the new replacement bulb housing has extra conduit/wire harness and the old did not have that. I don't know where to plug that harness/conduit. The right front passenger turn signal still works although I was told by the parts service guy to have both front turn signal bulb housing replaced as they have mentioned, MBenz has a service bulletin on it. It looks easy to replace I just don't know where that harness/wire/conduit gets plugged to. Please anyone who knows, please advice. Thank you.
I'm new to this site and a 1st time benz owner. Just bought myself a 2002 C32, with very low milege and got a great deal for it.
2 problem i have sofar with the car is turn signal is out on both side. and ticking noise on top of the dash. From what I read from this site its the stepping motors, which I will take care of that later since its gonna cost about $1.
I'm trying to fix the turn signals myself. Took the bulbs out and replace with new one, still didnt work. Use the info above from Bif, I bought 2 of the turn signal adapters from dealership $105 for the pair. I need help on disconnecting the wire from the main headlight harness. Is there a tool I can use to remove the wire from the harness? a pic of that tool will be nice.
thanks for any help in advance.
Great web site for research.
Thanks,
