Squeal when cold
Stevec32
Stevec32
I had the same issue. I ended having to grease one of the pulleys and now the noise is gone. Get a spray bottle with water and spray each pulley until you find out which one it is, and then grease the bearings. Should be able to do most of them with ease.
Also, you might need to change out your power steering fluid.
