Reset Service Lights
2002 S500
hello everyone, i have a 2002 C32, does anyone have any idea how to reset the service reminders, i want to reset mine because i don't think i should spend $500 for an oil change?
DM
DM
C32 AMG, CLK 320
It's in your manual. Oil change should only be $100. That's not a bad thing, your dealed will tell you if something else is wrong. Think of it as an inspection for free.
Enterprise rent-a-car!!!
Same way, ignition to position #2 not 3 (3 is crank) bring up the service menu via the steering wheel, push "R" and when instructed to do so release and push again to confirm. Message will then read "service has been reset".
One word of warning the drivers door must be closed otherwise it will not reset and could lock up the cluster.
