Delaied throttle response - a strange blirb ?
Old Feb 8, 2007 | 09:22 PM
gkstar's Avatar
C32 AMG - in Pewter
Delayed throttle response - a strange blirb ?
Just came back from shopping and a strange thing happened... and then went away. While driving on the highway, I noticed throttle response was very sluggish. Went to a parking lot, put the car in park and here: I press the gas pedal and nothing happens for about 2 seconds, then the car revs to the point where it should have been 1.5 sec ago. If I press all the way and release quickly, the rpm do not even go up at all. Car acted like a complete retard
So it is like the computer will register the required throttle only after 2 secs.
OK, turned the engine off and then started immediately - problem gone, response back to normal. Any idea
Old Feb 9, 2007 | 09:21 AM
sales@eurocharged.com's Avatar
SPONSOR
C63S
Humm...how many miles you got?
Old Feb 9, 2007 | 12:11 PM
gkstar's Avatar
C32 AMG - in Pewter
40k, not that much. I am suspecting an electrical glitch or noise. May not happen again, I hope.
This is kind of the exact opposite of what the spring booster does...
Old Feb 9, 2007 | 12:32 PM
jgsx's Avatar
04 C32
That happened to me one time when I was driving home from the dealer. It felt like the car went into limp mode for a few seconds, then changed its mind and caught back up. I'm not sure what caused it. It never happened again.
Old Feb 9, 2007 | 12:53 PM
TopGun32's Avatar
your compressor is not working....
that was exactly what I was feeling when my compressor would not engage.
from first at a stand still.... you fully press the depal and it would take like 2 seconds for the car to move.
I would have to shut off the car and restart to get it back.
You may need a battery? your clutch bearings are bad (easy fix) or your IC pump is out.
all are pretty much easy fixes.
Old Feb 9, 2007 | 01:47 PM
KatzManDu's Avatar
CL55 AMG (2001), Audi Allroad (2003)
I have a CL55 AMG... same issue!
Except I have a 2001 w/o a compressor... at least I don't think it's a compressor. I'm thinking it's something in the drive by wire or the throttle position sensor.
I just STFA for "throttle response" and your post came up first!
Old Feb 9, 2007 | 01:49 PM
gkstar's Avatar
C32 AMG - in Pewter
The S/C was my first thought, until I tested the delayed response while the car was in park. rpm would follow about two seconds after pedal press... I believe in Park, S/C is completely out of the picture (small exception - when you start the car in frosty morning then S/C engages for a few seconds to shake off ice build up).
Old Feb 9, 2007 | 01:57 PM
KatzManDu's Avatar
Yeah, most cars turn off any sort of forced induction when in "Park." I have the problem in reverse and going forward....
TopGun32's Avatar
do you have any error codes?
check engine?
and lighting codes (turn signal, brake light)
Old Feb 9, 2007 | 04:58 PM
KatzManDu's Avatar
One other idea...
Just came back from shopping...
Check this response to my query on the CL55 forum... it may give you some hope..
https://mbworld.org/forums/showthrea...42#post2003442
