TSW 19" Bremma weights
Old Mar 29, 2007 | 06:31 PM
  #51
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Originally Posted by Harry Madan
keep the car at 18" will not let me loose any power, but what if i was able to find a 18" with 235/265 set up. that would eliminate the problem of rubbing for sure, and increases the handling of the car. ? so would that work? or do u think since i don't want to loose any power. i should just stick with 225/255 setup
A 235/265 setup wouldn't necessarily eliminate the problem of rubbing (even if they are on 18" rims) because you have to consider that they will be taller tires than what would be on 19's. The thing that "saves" you is that the 235/265 setup on 18's is a very similar rolling diameter to the 19 inch setup.
That being said, if you want to be 100% sure you don't loose any power, go with the 225/255.
Old Mar 29, 2007 | 06:50 PM
  #52
Harry Madan's Avatar
03' E39 M5, 10' CLS63 AMG
ok sweet, thx
can u recommend some good wheels with a nice lip in the back?
Old Mar 29, 2007 | 11:16 PM
  #53
Eurocharged Rick's Avatar
SPONSOR
ok sweet, thx
TSW Thruxton's... i had 19x8 front and 19x9.5 rear
Old Mar 30, 2007 | 02:31 AM
  #54
drexappeal's Avatar
ok sweet, thx
Take a look at the Aftermarket Wheel thread in the w203 forum. There are some very nice wheels on there.
It really depends on what price range you are looking at. After that, you'd have to pick between lightweight/peformance vs. looks. If you want a combination of both, then it's a matter of whether you want to go 1 piece, 2 piece, or 3 piece. If you are down to spend the money, there are a lot of different choices. Just gotta decide what is exactly right for you. No matter what you do, be sure to do a lot of research before buying the rims. Don't just buy rims because they're inexpensive or they "look good". My theory is, buy them one time and be happy with them.
Or, if you're Mr. money bags like FrankW (j/k Frank ), you can switch to different rims every other year!...LOL.
Old Mar 30, 2007 | 01:48 PM
  #55
ok for sure, i will have to look around to find a good wheel for my car, but it seems like for the most part i will stick with the AMG for now, and then i guess the best bet would be to get the realy AMG 2 piece wheel, when i can save enough money for it but those wheels are really $$$ are they really worth the money? i have been told that they are a really light weight wheel?
Old Mar 30, 2007 | 02:14 PM
  #56
drexappeal's Avatar
Nope. The 18 inch AMG 2 piece wheels are heavier than my 3 piece 19 inch wheels.
