P2003 "Secondary Air Injection"
Old Mar 25, 2007 | 10:12 AM
timh718's Avatar
What is it?
I've got my engine lights on, and got the relay replace, DTC reset.. few weeks ago.. and enginelight back on yesterday. please help...
Old Mar 25, 2007 | 10:21 AM
timh718's Avatar
it's a C32..
power doesnt seems different..
mostly got engine light on while idle long..
Old Mar 25, 2007 | 11:09 AM
timh718's Avatar
just check out some old post..
if i just unplug it for a few months, will it have problem?
Old Mar 25, 2007 | 11:52 AM
Zeppelin's Avatar
C32
You can unplug the air pump and won't have a problem. It may or may not make the CEL go out. Have you checked the code to see if you still have the Secondary Air Injection causing the CEL. You can also check the relay to see if the contacts look burnt.
Old Mar 26, 2007 | 08:40 PM
Expat's Avatar
2002 C32
I had this problem at the time of the recall, the relay failed and burnt out the pump, the advice I was given is:
1) See if MB will cover its replacement under "Factory Assistence", the pump alone costs $800.
2) If you don't get it replaced then eventually you will poison your cats but that can take 10-20K miles.
