C32 tranny problem/???
. I decides to pull over, and follow the steps of resetting the ECU, Once i reset my ecu all when back to normal. Now my question is, does this happen often with c32's
? Or this is a problem i should bring it in to check it out ASAP? Any help would be greatly appreciated.
Out of curiousity, why would you be in 4th at 25mph anyway?
I hope nothing serious with the tranny, or engine
Does your's have the infamous "jerk" at ~1500rpm? I didn't look at the year of your car, but if it's an '02 C32 this is a very common problem. If you have extended warranty there is a fix for it. I just had mine done (see the "my saga continues" thread) and they replaced the valve somthing or other and the TCU. You might be able to kill two birds with one stone...
Have the dealer check it out. If you need the selector, you can have mine free of charge. (I ended up buying a new one because the cheap "chrome" trim around it cracked. Only way to replace the $3 plastic piece is to buy the electronic unit)
Assuming the trim piece around the selector is undamaged, you can just pop out the old electronic unit and replace it with this one. Takes about 10 minutes and no tools are required.
