Lighter rotor options?
2008 A8L, 2002 996TT X50, 2009 X5
I'm not exactly sure what you mean... OEM (Original Equipment Manufacturer) supply the factory, so aren't "factory MB parts" just OEM parts in an MB box?
If it helps answer your question, the rotors look exactly like the factory ones, however they don't have any MB stamps or part #s on them from what I can tell, and come in a box that says "MADE IN GERMANY" - but doesn't specifically say "MERCEDES-BENZ FACTORY ORIGINAL PARTS"
But will they work!? its just plug & play or what!?
Anyone tried yet?!
I was searching and looks like brembo has some rotors for the C55!
front
http://www.buybrakes.com/brembo/spor...es%20Benz.html
rear cross drilled
http://www.buybrakes.com/store/BR35205
http://group5motorsport.com/brembo/b.../i-127723.aspx
http://group5motorsport.com/rotora/r...c/i-91315.aspx
I also finded that some rotor manufacturers say "OEM brembo brakes compatible"...
Anyone tried yet?!
front
rear cross drilled
The only effective way to reduce weight would be to go with a two piece rotor iron friction surface and an aluminum hat, or using a carbon ceramic friction surface. The CCM option would be cost prohibitive so a two piece system would be the best bet. The last thing you want to so is reduce the dimensions of the original rotor. The Mass of the rotor has a lot to do with its thermal capacity, and you don't want to reduce that.
'08 CLK320CDI AMG// '13 E500 Coupe AMG// '17 E350d AMG
The rear rotors showed all are for C55 and some other MB models that use the same rotor, but for the front one I only found for SLK350 with sport pack, aren't the same as the C55 ones? I read that somewhere else...
