It's probably in the Manual, but I'll ask here. Oil fill.
Old Apr 9, 2007 | 11:41 AM
Fifth Ring's Avatar
C32 AMG
I changed the oil/filter last night, and did the "test" to see if it was full enough. The message said something about servicing the car at its regular interval. Does that mean oil level is OK? I put in about 7-1/2 quarts.
Old Apr 9, 2007 | 11:57 AM
boohooramblers's Avatar
Not an AMG :(
It should have told you it was 'OK', add some, or too much!
Out of curiosity, when you measured, did the system give the following prompts?
1. make sure the car is on level surface....
2. measuring oil level....
3. [results of measurement]
Old Apr 9, 2007 | 12:42 PM
Fifth Ring's Avatar
C32 AMG
Yes, I got those messages. Maybe it's a bit low.
Old Apr 9, 2007 | 02:59 PM
Eurocharged Rick's Avatar
SPONSOR
i remember asking this question when i first got my car, the car usually needs to be driven a few miles first, then it will give you a reading...or something to that effect...
Old Apr 9, 2007 | 04:48 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
The interval message just says that the car is not warm enough or is too hot to measure the oil.... It is in the manual..........
Old Apr 9, 2007 | 05:07 PM
Fifth Ring's Avatar
C32 AMG
Thanks. Why doesn't the message just say that!
Old Apr 9, 2007 | 06:56 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
I have no idea, it is a very misleading message.
Old Apr 10, 2007 | 01:09 AM
Zewerr's Avatar
Woot, first post for me.
All you really need to do after you change the oil, fire it up to let the oil circulate. Then shut it off. If the engine is warm, it usually takes 5 minutes, if it's cold, it could take about 15-20 minutes for the oil to settle, and then it'll give you a reading.
