C32 Oil leak question
Old Apr 23, 2007 | 10:03 PM
ForcFed's Avatar
C32
I have some oil coming from either the front main or the oil pan. Any one have any experience with a leak in either place? I can not wait to go to the dealer for this one. Maybe I can avoid it. The car has is a 2003 and has 54,000 miles. Will any dealers stretch the warranty?
Old Apr 23, 2007 | 11:03 PM
gkstar's Avatar
C32 AMG - in Pewter
Did you do oil change recently? I have heard about oil filter not being seated properly can cause that...
Old Apr 23, 2007 | 11:09 PM
ForcFed's Avatar
C32
No, I got under the car and pulled the undercarriage protection. I sprayed the oil off with brake clean. It is coming from the front main or the pan I am almost positive.
Old Apr 23, 2007 | 11:11 PM
ForcFed's Avatar
C32
The dealer did change the oil at 50,000 miles. I am not sure when the leak started. I went to the track this weekend and noticed the burning smell after the first run. Obviously had nothig to do with that as I noticed it is all under the car.
Old Apr 24, 2007 | 02:17 AM
timh718's Avatar
check if there's 2 must gearbox oil..
Old Apr 24, 2007 | 10:18 PM
ForcFed's Avatar
C32
It is not leaking from the filter area. For sure from the main seal or the pan. I was wondering if they have any problems with this. Is the front main something that can be replaced by owner or are special tools required other than the seal tool?
