Oil leak passanger side valve cover?
Old May 4, 2007 | 04:14 PM
hkycoldrct's Avatar
2002 C32 ///AMG
I took a quick peak under the air inlet box on top of the valve cover to see how tight the spark plug and wire changout will be and notice a pretty good amount of oil and dirt gunked on the top portion of the valve cover? Anyone know what this may be? Is it just the valve cover needing a little tightening or is there something else potentially going wrong here? '02 C32.
Old May 4, 2007 | 05:07 PM
moorfan's Avatar
2002 C32
I believe this topic was covered about a month ago in this forum. There is no actual valve cover gasket under that little cover. It needs to be removed, cleaned, and retorqued with RTV.
Old May 4, 2007 | 07:10 PM
hkycoldrct's Avatar
2002 C32 ///AMG
Moorfan, thanks for the information.....RTV???
Old May 4, 2007 | 07:38 PM
sales@eurocharged.com's Avatar
SPONSOR
C63S
RTV can mean two things....one is make sure you tighten things to the right trq, and the other is a silicone based sealant used in gasket making.
At any rate, I would bring her in for another opinion....
My friend, usedc32, went through the same thing, maybe he can help.
Old May 5, 2007 | 10:50 AM
moorfan's Avatar
2002 C32
Sorry dude...I didn't realize that RTV had multiple meanings. I meant RTV sealant.
Here's the thread from before...I assume this is where you are leaking oil?
https://mbworld.org/forums/c32-amg-c55-amg-w203/188530-gasket-identification-help-oil-leak.html
Regards,
Pete
Old May 5, 2007 | 02:22 PM
hkycoldrct's Avatar
2002 C32 ///AMG
Sure enought that looks to be similar to what I am experiencing. I still have a few months left on a CPO warranty and I'm gonna bring it up to the dealership to see if they wount pull, clean and re-seal it first.
Thanks for the redirect to the other post.....
