Gasket identification help - oil leak
Also, is there a standard PCV valve on these cars? If so, where is it located?
Thanks!
There is no PCV valve in the circuit. It’s a closed-loop system like any other crankcase vapor containment design. However, because the vapors are readmitted into the system upstream of the throttle blade, there is no traditional PCV valve. The breather hoses (connected to the splitter) are only exposed to the slight negative pressure in the airbox tract, not intake manifold vacuum as we’re accustomed to in other marques.
Sorry, I don’t have the part numbers for the housing gaskets, but they are available separately.
Regards,
pete
You and moorfan are indeed correct. I beg your pardon.
The approved seal between the cam cover and breather housing is actually RTV silicone. I had looked in my old hardcopy screenshots of the EPC, where it showed a gasket. Visited my dealer’s parts department manager on the way home from work today. He had a new cover in stock. Of course, it had the ubiquitous silicone seal.
Just shows to go ya, you can’t believe everything I post.
Sorry about that. I owe you a tube of Permatex!
You can make up for it by providing me with the torque specs on the cover bolts
I picked up the RTV and want to take care of this tonight. Thanks.
What is the best strategy for applying that RTV so that it doesn't 'pooch' inwards and potentially drop down?
Thanks!
By the way, the cover bolts were loose. If you are just getting some oil vapor/dirt around your cover, I woulld clean it up, and try retorquing the bolts first. That might be all thats needed. Since my car is higher mileage, I took care of the gasket.
For the bad news of the night. I decided to retorque the valve cover bolts. I got the spec, and started tightening them. SOme needed alittle tightening, and all went fine, until the last one. I was waiting for the torque wrench to give away, but the bolt did first...$*&#^&$*)#&^*)$# So...It broke towards the top of the bolt, which leaves me some room to try and get some needlenose on it to back it out. Its too narrow to try and tap. That was the only good news was that the bolt was still threaded, and didnt break off inside.
For the bad news of the night....... I was waiting for the torque wrench to give away, but the bolt did first...$*&#^&$*)#&^*)$# So...It broke towards the top of the bolt, which leaves me some room to try and get some needlenose on it to back it out. Its too narrow to try and tap. That was the only good news was that the bolt was still threaded, and didnt break off inside.
Regards,
Pete
Honestly, its happened to me once before on another vehicle. On that car, I had to pull the cover to get the bolt out. I am crossing my fingers that wont happen here.
Because you asked privately to borrow my W203 service DVD to help resolve some of your car’s idiosyncrasies, I felt compelled to offer assistance to a fellow AMG owner and MBWorld member.
I’ve enjoyed working with and improving the performance of my cars for more than three decades. There are few things, besides family and my livelihood, which provide greater pleasure than my beloved mechanical toys. I’ve willingly loaned and shared tools, techniques, knowledge and literature with myriad fellow enthusiasts over the years. Never, not even once, has any item I’ve loaned failed to be returned in a timely manner. Until now. I’ve busted many a knuckle, on several occasions, to aid a friend or fellow automobile aficionado. I will continue to do so because it’s ingrained in my (however faulty) character.
When I paid to send my disk (via overnight express) to you early last month, it was with the expectation that you would return it in due course. Unfortunately, you have not yet returned the disk. As I have communicated with you, I have several pending projects that require due diligence and research from my MB service disk.
Alas, you have continued to ignore my Emails and PMs about its return. Why have I been rebuffed for my sincere attempt to help you?
John
Received the disk with today’s mail. I very much appreciate you getting it back to me.
My faith in car-crazy acquaintances has been restored. Thank you!
I currently have my CC vented to atmosphere through a catch can. I have a few plans to use a vacuum pump to evac the CC. I would like to better understand the C32 system to see what factory uses on a production F/I setup. I personally like the idea of using engine vacuum as it's free, but don't want to pull the CC gases and oil mist through the blower....
...to keep this on topic I'm also changing the same exact gaskets this weekend.
