Need Help on ASP pulleys URGENT!!!
Hi, I took off my aftermarket pulleys on my C32 today and put the OEM pulleys back on. Now when i first start up the car, i will hear this squeaking noise. My tech told me it's because the larger aftermarket crank pulley stretched the belt a little bit and cause the belt to be loose around the OEM pulleys. therefore making the noise. But my belt was almost brand new as it was replaced about three weeks ago. Will three weeks on a aftermarket pulley really stretche the belt that much? Also, i thought even though the crank pulley is bigger than OEM and water pump and idler pulley are smaller. So the overall length should be the same. Is there anybody else with aftermarket pulley had this same problem when they put the OEM back on? Please help. Any info will be appreciated.
thanks
