The New brakes are here !
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
the silver finish on the rotors are going to be going in matter of min's too. it is just painted to help the brake pads settle into the rotor.
i think i will improve braking power in my car because i'm going to a bigger braking surface in the front and the back, where i was at a 4 piston braking in the front now i will be at a 6 piston, increasing the surface of braking on the rotor, will indeed improve the braking power i agree it may not be a really big significant increases but non the less it will be an increases and with the 2 part rotor i will no longer have any heat transfer, thus always have the ultimate temperature to ideal braking power. where the braking power of the car will stay constant longer. not like currently where the braking power starts to fade as they get hotter and hotter.
actually some heat trasfer is good. now your rotor no longer heat sinks to the hats and then to the wheel. your rotor temps will be higher (disregarding the effects of it's added mass)
if you're losing braking power as your temps increase you have a problem with your pads and or fluid.
anyway....all this said i wish i was the one who was about to install these on his car.
and i have noticed my car loosing braking power on the highways from high speed braking. so it was an up grade that i was going to get no matter what, and now if i ever increases the power of my car i will not have to worry about stopping. ya I can bring them along to the next meet so u can take a look at them.
#32
2004 C32 ///AMG
If your stock C32 brakes were losing braking power on high speed braking, then you had a mechanical problem. Any street use is wll within C32 brake capabilities. No doubt, there are LOTS of reasons to get big brakes, including pure aesthetics. But not to solve a problem with C32 OEM brakes.
#35
2002 AMG C32 2006 Audi A4 Avant
great job
how about some numbers on how much the front & rear calipers & rotors in comparision to the stock ones? what model car did they come off of?? my friend has a slk 55 & they look like the ones from the slk 55. last question... how much did they cost in comparison to factory brembos or ap racing??
thanks!!
thanks!!
#37
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Harry, did you get the sensors also? If so, could you pm me the part number when you get a chance? Thanks, drex.
#39
EVE
Are these "wider" than the C32 brakes at all or just significantly taller? I shy away from this only because I'm not sure they'll fit my 18" LMs...but I see you've got 18" AMGs as well.
Looks awesome!
Looks awesome!
#40
'09 A4 S Line
As close as your calipers are to your spokes, you should definitely be concerned about fitment.
#41
1 Post
03' E39 M5, 10' CLS63 AMG
the calipers are a little wider then the C32 stock caliper. i will post the full measurements when i get a chance.
#42
'09 A4 S Line
Not necessarily. Offset is one part of the equation...spoke design and thickness is the other. With 30ET up front, Jose has about a credit card thick space between the C32 brakes and his spokes.
#44
'09 A4 S Line
#45
EVE
