lowering the c55
2005 C55 ////AMG
lowering the c55
hey guys,
i need some help with springs for my c55...i keep rubbing everytime i hit anything becuase of the weight from my system..anyone direct me towards the right options?...thankz!
The only sure fire solution is coilovers because you can adjust ride height. Everything else is guesswork. Search PSS9s
if the C55 is the same as the C32, then you could check to see if you have the thickest pad in the rear for the springs...thickest pad is #4, if you have anything under that, then you might be able to get enough clearance to not rub by going to a thicker pad...just my .02
Good thought. The spacers are really inexpensive, so the entire investment is labor. When you say that they are rubbing due to the "weight from your system"? Are you referring to your sound system? If it is a new problem caused by adding weight, then the #4 spacer may be a solution. It will simply raise the back of the car. If you don't want to raise the back of the car, you need to go with a firmer spring that does not compress as much over bumps. Of course that makes the ride firmer too.
