2007 c230 6 spoke wheels dont fit on my c32???? help
From what I've seen, all the MBZ wheels of recent vintage are the same 66.5mm hub diameter & even the same 5x112 bolt circle, so they should bolt on even if the offset is wrong.
If these are not factory Mercedes wheels, then you probably just need to get the correct centering ring. Most aftermarket wheels are made with a "one size fits all" hub center, then they have a separate small ring that fills the gap.
Off topic but since your a C32 owner Can i ask if your bolts are shorter in the back than the front?
