Need help on 2 things
Old Jul 17, 2007 | 03:11 PM
Derrick9191's Avatar
Mercedes C32
I have a couple of questions. I did a search and couldn't find these anwsers so maybe you guys can help.
1. My cruise control does not work. I was wondering if there is a fuse or something easy like that to get it going again?
2. My sunroof does not work properly as well. If i push the button it opens alittle and does not open all the way. I have to keep pusing it until it is open. but when you close it all i have to do is hit it once. its weird but maybe something easy.
Thanks in advance. oh ya this is on a 2002 c32
Old Jul 17, 2007 | 03:28 PM
///AMG4EVER's Avatar
CLS55 Designo 030
Try reprogramming the sunroof by holding/pushing the button for a few seconds.
Old Jul 17, 2007 | 03:35 PM
F1ferrari's Avatar
'05 C55 AMG
I had the same problem and took it the dealer... They had to re-lube the tracks.
Old Jul 17, 2007 | 04:34 PM
ericpd's Avatar
2003 C32 AMG & 2009 CTS-V
Did you recently disconnect your battery or lost power somehow? If so, then AMG4EVER's advice should set you straight. It might be mechanical, in that case F1 is more likely on the right track! Try cynchronizing first tho!
Old Jul 17, 2007 | 05:54 PM
Mercedes C32
what do you mean to cynchronize? also I didnt have a battery problem but the cruise control didnt work before i had the problem. Now the sunroof was working before the battery problem.
