New H&S ECU in my '03 C32 reactions
Old Oct 17, 2002 | 04:15 AM
Pierre32///AMG's Avatar
Porsche Turbo Stage 4, Cayenne S ... gone C43, C32, ML55 & Ducati 999.
Exclamation New H&S ECU in my '03 C32 reactions
Well, after 250 miles with this new H&S ECU I have just one word:
..TORQUE!!!!
1. Out of the line is quicker, and explosive.
2. At the highway the car is FAR quicker and 130-140 is so easy to reach. Among third and fourth the shifting is quicker.
3. Same top RPM.
4. The car sounds louder, cooler, and deeper.
5. I feel the Kompressor working more efficiently and “listen/hear-able”.
6. Between 800-3,500 is better than stock specially the reaction.
7. Between 3,500-5,500 the improve in torque considerable, I really fell my back squash the sit. It really makes me remember my Fiat Turbo when reached 1.6 -1.8 bar when the turbo opened. If I need it to compare with the stock C32, imagine that in this range you gave an “over boost” that may be generated from better timing and flue efficient mixture.
8. Between 5,000-6,220, I feel quicker than stock but I must say that the improvement in torque is that big, which makes me lost the sense or perception that where is the improvement in the other RPMs.
Finally, I’m waiting for the BMC panel filters, and I’m thinking to replace the plastic Y-connector that brings both sides into throttle body from the SL55 Kompressor (Bigger diameter). After everything is done (ECU, BMC filter, and Bigger Y-connector) I will dyno and post.
Bye
Pierre32///AMG
Old Oct 17, 2002 | 10:04 AM
Bux's Avatar
Bux
G
badass ..will the sl55 y-connector fit? and how much for H&S ecu?!
Old Oct 17, 2002 | 11:11 AM
Zeppelin's Avatar
C32
What octance gas dos H&S recommend for this chip? Unfortunately 91 is all we get here in CA.
Old Oct 17, 2002 | 12:26 PM
-Will the sl55 y-connector fit? I don't know but I'll try.
-How much for H&S ecu? US$ 1,290 with shipping to Germany and return.
-What octane gas dos H&S? well I higher better, Thomas told me that the program that the upload in the OEM ECU does set up depending the octane. Thus, the figures that you may see at the H&S web are the minimum that you may get. Also he replayed to me that they had used the same program with 100 octanes in Germany and of course the car goes much faster.
Finally I had the H&S ECU on my old C43 and works excellent for a year, so far.
bye.
Pierre32///AMG
Old Oct 17, 2002 | 12:43 PM
bverotti's Avatar
C32
I had a look the the H&S specification.
450 NM to 485 NM
354 HP to 376 HP.
You may indeed feel a small improvement, but really this is nothing to be shouting about. For the price you paid I would say it"s ok.
I am waiting and hoping for something to come out in the 450 HP range with a torque about 540. That is what I think of in terms of feeling the extra power in your but ! MKB kit is close, but at a price of 10-11000 $ ... forget it !
I hope vadim comes along soon and bring us an extra 100 HP for XMAS !
Old Oct 17, 2002 | 01:29 PM
Bux's Avatar
Bux
G
so pierre how much down time did you have until you got your ecu back?
Old Oct 17, 2002 | 01:30 PM
Thanks bverotti,
by the way the H&S specification in torque is right (450 NM to 485 NM) but the hp are not right added (354 HP to 376 HP) because they claim 26 hp more, thus 380Hp and Thomas excused for that.
Bye
Old Oct 17, 2002 | 01:39 PM
ro0zy, I sent it by FedEx 2 days to Germ. $50 on Tuesday the 8th with the payment inside, and got it here early Monday.
Bye
Old Oct 17, 2002 | 01:44 PM
WayneE's Avatar
'72 Suburban
Re: New H&S ECU in my '03 C32 reactions
Bye
Did you dyno before the mods?
What does H&S claim to do to gain all of this HP?
ECU modifications on NA cars aren't worth squat, except to advance timing so you have to run higher octane fuel. Even then there isn't much gain. You can give a better SOTP feeling by playing with the fueling and ignition timing, but overall power isn't increased by a whole lot.
When you get to turbo or supercharged cars, you can realize huge gains by upping the boost and adjusting the ECU settings accordingly. However, just an ECU change without increasing boost pressure (pulley change on supercharged car) is not likely to free up 26hp with no other changes. It seems unlikely that Mercedes left that much HP on the table when tuning the SLK/C32.
Aftermarket tuners can make a lot of claims for power gains, but it's not necessarily how it's going to perform on YOUR car. Many times tuners will make a bunch of modifications to the car (like intake changes, cams, heads, exhaust, etc) and run it with the stock ECU. Then they'll run a modified ECU and see huge gains due to tuning for the other mods. They can now claim that they saw XX gains on XX car, when it's not really applicable to your average joe who's only making an ECU change on an otherwise stock car.
Anyway, just my .02. I'd be interested in seeing a before/after dyno of just the ECU and also the corresponding A/F measurement from a wideband O2 for both before and after.
Old Nov 6, 2002 | 12:31 PM
Fast Eddy's Avatar
Smart Car
Re: Re: New H&S ECU in my '03 C32 reactions
Totally agree, I feel that my car is a rocket every time I get it after the service is beeing done and that is only because I have been driving loaner for the time of service. I also used Sunoco 94 octane gas and it felt quicker--------I don't know if it were just the feeling may be because I expected some difference from better gas. Personally I do not believe that you can feel much difference from ECU change so I say Pierre simply was out of his car for a week and that is what felt different to him.
Old Nov 7, 2002 | 01:00 AM
Re: Re: Re: New H&S ECU in my '03 C32 reactions
Typical C32 is around 285HP and 275TQ at the DYNOJET. I did 309 HP and 305 TQ, and no speed limiter; what do you think? 40Nm more....
besides "Personally I do not believe that you can feel much difference from ECU change so I say Pierre..." well look this:
http://www.hs-elektronik.com/datenbl...3ps-752nm.html
Old Nov 7, 2002 | 05:20 AM
IanPooley's Avatar
Schrempps C 32 AMG
91??? LOL!!!!! Uhahahaaaaa
Old Nov 7, 2002 | 05:24 PM
rrf's Avatar
rrf
Yes 91 sucks
Ian you are right 91 sucks in CA. BUT our US octane ratings are more conservative than German. Somebody help me, what is 91 CA Octane equivalent in Germany?
Old Nov 7, 2002 | 06:16 PM
Re: Yes 91 sucks
I believe that 91 CA Octane equivalent in Germany 94-95.
Old Nov 8, 2002 | 04:19 AM
IanPooley's Avatar
Schrempps C 32 AMG
Hi,
if you have fuel with 91 octane in the US then it´s the same fuel with 91 octane in germany. There is no difference. 91 octane is 91 octane
In germany you will find 3 categories:
- Super (95 octane)
- Super Plus (98 octane)
- Optimax (100 octane)
Mercedes-AMG says that its recommended to drive super but i always drive super plus. It´s better for the engine cause of the "cleaning effect". And maybe the engine reacts more powerfull.
One 4 times a year I drive optimax. But you can only get optimax @ shell fuel stations.
Old Nov 8, 2002 | 11:23 AM
Zeppelin's Avatar
C32
Originally posted by IanPooley
Hi,
- Super (95 octane)
If Mercedes recommends Super(95 octane) then your cars either make 30 more horsepower than the California model or it is severely under-tuned and they could get another 30hp running 95 octane.
Old Nov 8, 2002 | 01:39 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
this might be off-topic, but has anyone heard the high pitch noise when the car is over 140 mph? Finally drove it up to 158 mph (the speedo is off at that speed about 3-4%). after 140 the audio is automatically turned off, but i also get this weird high pitch noise from the center console after the audio is off. is that supposed to happened?
Old Nov 8, 2002 | 01:48 PM
Mach430's Avatar
It's not your supercharger screaming?
Old Nov 8, 2002 | 01:55 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
haha...u funny Ben
No, it's not from the s/c. the noise appear immediate after the audio is off.
Old Nov 8, 2002 | 02:09 PM
JustinTRW's Avatar
C32 AMG
You would listen to the radio during performance driving? You are missing out man.
Old Nov 8, 2002 | 03:18 PM
awiner's Avatar
2003 CL55 AMG
Hi,
Not entirely true. In germany I beleive they rate fuel on the MON system whereas in America we rate on the RON system. The octane #'s therefore will be different between the two.
Old Nov 8, 2002 | 03:47 PM
IanPooley's Avatar
Schrempps C 32 AMG
"its getting hot in here..."
Yo Frank!
you´re right: I have this screaming noise too. But my radio doesnt switch off automaticly. AMG makes this special for EU cars cause the driver should know that the speedlimiter starts with his work.... Everythin´is allright with your car.
Old Nov 8, 2002 | 04:00 PM
IanPooley's Avatar
Schrempps C 32 AMG
Hm... good question. But you are right. For example: my fathers porsche needs "super plus" (98 octane). We asked a Ruf technitian and he told us that if we use super fuel (95 octane) that we will lose much HP and you need more fuel.
Same thing with the benz. And didn´t some1 write somethin about dyno and his car that has ~ 300 HP? My car hast 354 HP and is the same as his one...
@ FrankW: AMG told me that if your car (C 32 AMG) is delimited on the 1st stage it will run 280 kmh. With full delimitation (2nd stage) it makes 10 - 15 kmh more. Thats 290 - 295 kmh!! Imagine that...
Old Nov 8, 2002 | 04:03 PM
Mach430's Avatar
His dynograph reflected wheel HP, not engine HP. All C32's have approximately 354HP at the crank.
Old Nov 11, 2002 | 04:55 AM
IanPooley's Avatar
Schrempps C 32 AMG
Ok, thank you!
