Got my LET C32 Pully kit!
Thanks Erick, LET the fun begin....
I can't wait to get my upgrade next weekend!
I want to upgrade the cooling system before installing the larger crank pulley. Too much boost will only increase IAT and make the DME pull timing.
Too much to mod, too little time.
Are your heads ported? If so, then you are in for a wild ride. If you want a larger pulley later, you can leave the silver part of the pulley on the car and just swap the black part out in about 20 minutes!
I have put over 1200 miles on LET pulley and all is well.
alot! i gained 35 rwtq and 12 hp going from the renntech pulley setup...
this is with the car pulling some timing on the top end...you can definitely feel the torque...
I installed the crank pulley many times without the air gun. Under neat the tranny, there's two black plastic cap/cover. Remove those covers and you can see the torque convertor. Just find a big flat bar and stick it in there and you will be able to jam the torque convertor. This job would be very easy if you can find another person on top to remove the crank pulley nut/bolt while you down low lock up the torque convertor.
Go for it!! You will be happy.
22 pounds of boost? Good lord that is right at the max for the blower. That thing must be making buckets of heat! But that is a lot of power!
(ideas are coming in now)
