Got my LET C32 Pully kit!
Old 11-10-2007, 05:54 PM
steve_bris's Avatar
C32
Thanks for the info Clk&Slk, that is really useful ...... if anyone has any pics of the gearbox can they post them, so we can see where the access to the torque convertor is.
Old 11-10-2007, 07:34 PM
Ted Baldwin's Avatar
300ce
Originally Posted by CynCarvin32
Just one belt.
22 pounds of boost? Good lord that is right at the max for the blower. That thing must be making buckets of heat! But that is a lot of power!
.............I just go through looking at the engine bay of a C32 for the first time. A guy brought his over for me to see. As far as I can tell, the idler pulley is smooth and not ribbed. The alternator and power steering pullies are 8 ribbed pullies. Am I correct? Thanks.
Ted
Old 11-10-2007, 07:37 PM
pshek's Avatar
2003 C-Class Sportcoupe
Ted
Yes, they are 8 ribbed.
Old 11-10-2007, 07:56 PM
300ce
...........Thanks!! Now the real question is; Do you think I can swap my W210 E55 single 6 rib belt system with a C32 single 8 rib belt system by swapping all the pullies. Assume that I have a brand spanking newly rebuilt W210 E55 engine with 8.5:1 compression with a Kleemann s/c, and I wish to take advantage of the various C32 higher boos crank pullies. Yes, I already have an 8 rib s/c pulley. Vary eager to hear your reply. Thanks.
Ted
Old 11-10-2007, 08:57 PM
SPONSOR
Eurocharged Rick's Avatar
Ted
i know for sure you would have to use the A/C compressor from the C32, as you can not remove the pulley...everything else may come down to an alignment issue for the belt...
Old 11-10-2007, 09:02 PM
300ce
.............Good tip. Thanks! I am definitely going to try this. I don't mind swapping the ac compressor. If I can consent to having my entire engine rebuilt, swapping an ac compressor will be no big deal. I was mostly concerned about harmonic balance between the V6 crank pulley vs the v8 crank pulley. However I notice that most Mercedes V6 and V8 engines use the same oem crank pulley.
Ted
Old 11-10-2007, 09:49 PM
  #32
SPONSOR
Ted
yes, but having your engine rebuilt is much different than trying to fabricate new brackets so that all the accesories line up correctly along with making sure the belt is routed correctly over a ribbed or a smooth surface... you may want to do some research before you start purchasing these items...a new A/C compressor for the C32 is $1150.00 if i remember correctly...
Old 11-10-2007, 11:11 PM
  #33
SPONSOR
Originally Posted by steve_bris
Unfortunatly I don't acess to an air gun at all ........ and with the stock/asp pulleys you can lock the crank with the holes in the pulley and remove it with a normal ratchet .... if there is any way to lock the crank and get the LET pulley on and off at home with a ratchet i would go for it
Steve, here is a pic for you, you can see how much room there is once you remove the radiator fan...
Old 11-11-2007, 01:46 AM
  #34
D_Star's Avatar
05 CLK55
That's what I am concerned about. Will the pulley put stress on the blower in a long run? also, does the LET pulley need to run with a ecu tunning?
Old 11-11-2007, 01:56 AM
  #35
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
LET Stage 1 will utilize Evotech software. Ask Erick for details.
Old 11-11-2007, 02:54 AM
  #36
amgstyle's Avatar
2002 SLK 32 AMG
i have the evo pullies. are the let pullies bigger? and does it produce more boost?
Old 11-11-2007, 02:58 AM
  #37
300ce
................understood. I am not going to be doing this with my own hands. I have absolutely no illusion that this is going to work. If the project works, it will be great. If not, the old pullies go back on and the C32 parts go on ebay. That part is not a problem.
.........My questions were to determine if it is feasible. I know that an AC compressor is expensive. I recently had one changed on my CLK for the same price. Unfortunately for those that choose to modify their cars, having to change an Ac compressor is not daunting if the overall project is feasible. The power steering pulley is also sold as a unit at the dealer. It is not sold separately. One can probably go the aftermarket route and purchase a complete stage one C32 kit and a new AC compressor. Thank you for your input.
Ted
Old 11-11-2007, 01:31 PM
  #38
SPONSOR
sales@eurocharged.com's Avatar
C63S
Yes and Yes.
Old 11-11-2007, 10:35 PM
  #39
1qikctr's Avatar
Merc power
damm makes me wanting more Mods, LET evo stg1 tunnin. Dammmm this tread sparked up the Mod bug . Grt info and pixs guys !
Old 11-11-2007, 11:54 PM
  #40
SPONSOR
Originally Posted by AMG-Jerry
Yes and Yes.
i concur! thanks Jerry!
Old 11-12-2007, 02:28 PM
  #41
430
430's Avatar
SLK32
Ted,
Let me know if you need stock pullies. I have my pulley's (crank, idler, water pump) from my SLK32 in the garage. The crank pulley was replaced under warranty and has a couple of hundred miles on it.
If you are interested I am sure we can work something out and I can talk with Rich about getting the pulley's over to the shop.
Old 11-12-2007, 02:53 PM
  #42
OJwerks's Avatar
not stock.
Anyone here have a clue if those LET headers work on SLK32 / 320 ???
Old 11-12-2007, 03:15 PM
  #43
SPONSOR
C63S
No, the C32 headers won't fit.
Old 11-12-2007, 04:51 PM
  #44
430
430's Avatar
SLK32
I have heard rumors that LET will build headers for the SLK32/320 in the future. But right now the only option is Steve's headers.
I am very much looking forward to my LET pulleys. They look and sound like a great product.
Old 11-14-2007, 01:01 AM
  #45
SPONSOR
Thanks! LET will be pursuing a SLK32/SRT-6 header design in the near future...hopefully there will be some updates soon!
Old 11-14-2007, 05:15 AM
  #46
steve_bris's Avatar
C32
The following link is an writeup with pics of an ASP pully onto a CLS55 ... do we have the same gearbox as them, so the Torque Convertor hole that you guys talked about will be the same as in these pics ....... also did you need the puller to get it off initially?
https://mbworld.org/forums/c219/182513-installation-asp-pulley-pics.html#post2030131
Old 11-14-2007, 08:33 AM
  #47
SPONSOR
https://mbworld.org/forums/showthread.php?p=2030131
steve, our access hole looks a little different, but you can't miss it if you get under the car...there are 2 access holes on our car and they are small rectangles...i will try to take a pic for you next time i have the car jacked up...
Old 11-14-2007, 03:49 PM
  #48
steve_bris's Avatar
C32
Thanks for the help guys ..... I will get under there and have a look on the weekend
Old 11-14-2007, 08:56 PM
  #49
amgstyle's Avatar
2002 SLK 32 AMG
hey does anybody know the size of the evo pullies?? are the let pullies bigger?? thanks for the help.
Old 11-14-2007, 09:05 PM
  #50
SPONSOR
evo pulleys are 178mm, LETMotorsports Pulleys are 185mm...
Quick Reply: Got my LET C32 Pully kit!
