Which Pulley??
Okay, so you are thinking that a 2-3 lb loss on recipricating mass is going to give you a 10to20 percent gain in mileage? Sorry but the math doesn't add up. The entire rotating assembly, crank, pistons, rods, cams, torque convertor weighs in at over 100 lbs. There is NO way a 2% reduction in mass can give you that increase in mileage. It just doesn't add up my friend. TOO many compaines report BS like this trying to get you to BUY in.
A side note, I tried undrive/ligther pullies on my stang, awhile back before the blower. I made 3 passes at the drag strip 14.3 at 96 mph, put the pullies on, LATER in the night with COOLER air, and guess what, 14.3 at 96 mph.
Moral of the story, DON'T BELEIVE EVERYTHING YOU READ
See yeah
PS: On my way home that night it started to rain, with the A/C on, headlights, and stereo on, each time my wipers would click on, the Volt meter would go into the red. I sold the pullies later that week for about 2/3 of what I paid and NEVER looked back
General engine theory states that ever pound taken off crank pulley equates to roughly 2.7-3 wheel HP-tq. Most lightweight crank pulleys for euro cars are between 4-7lbs lighter so its simple math.
E36 M3 boys have been using them for years, they dyno 10-12HP every time single time and have been proven to work. I'm not gonna rehash 30 years of proven dynos. Lightweight Crank pulleys have been proven time and time again to work simple as that.
I agree underdrive pulleys suck thats why I would only do stock diameter lightweight crank pulleys.
First thing, I am not looking to bash here, but the E36 boys, Vadium being the one who did it/dyno, and I REALLY RESPECT HIM, used aluminum, under drive pullies to get those numbers.
By the way where did you get General engine theory states that ever pound taken off crank pulley equates to roughly 2.7-3 wheel HP-tq? I have seen this on the recipracting mass, ie piston,rods, crank, but NOT flywheels, pullies.
Second, why does EVERY flywheel manufactures only claim faster reving/braking with a aluminum flywheel, and NO horsepower increase, as the flywheel shaves 15 plus pounds. Some even OVER 30 lbs on the old HIPOS!
I am just saying that balancer mass decrease does NOT gaurentee BIG horsepower increase. Your money can be better off spent in other directions.
You may see some gain, no argument here, but you will not pick up that HUGE mileage increase.
And you are right about ET NOT being a good indicator, however MPH IS A VERY GOOD indicator of HP.
See yeah
By the way, yeah under drive pullies for street cars do suck my friend
E55 PWR: I do not mean to pick on you, but everything that you just stated goes against my 27 years of experience of working on cars. It is exactly opposite and simply sounds like a typicall marketing lingo coming out of many young, inexperiences companies.
I know you aren't trying to pic on me but you just are not correct in this matter.
Now I just wonder if the VRUS UDP matches up in quality and performance against the EVOSPORT UPD for a C55.
The reason I do not want a different sized Crank Pulley is because I am already making 6+psi on my HPS SC kit and it would not be safe to run beyond that on a 11:1 compression ratio C55 motor.
btw... Both of these pullies are for Natually Aspirated C55s. My HPS kit uses the same pullies as a stock C55. Only thing the kit adds is a SC pulley made by HPS. Many stock C55 owners have reported great results with the AMS + EVOSPORT pulley combination. I think it's the safest mod for non-blown C55s and will not affect the warranty.
Sorry, I do not care to argue with you. It is obvious to me that you have some kind of interest in AMS and will keep pushing their product.
I wish you best of luck.
