Need some help! Car runs like crap
P.S.
Did not replace the center speaker or mid-sub in the rear because it would've been too much work.
Does anyone know where I can buy maf sensor for cheap. Cause the stealership charges way too much.
Did you get the code that caused the MIL (Check Engine Light)?
Sounds like a sensor wire might be out of place, or an Ignition cable might be off.
First off, check the code. If you don't have a code reader, go get the cheap unit from autozone or sears.
It's could be the MAF (non C32), MAP (C32), or ignition cable. Did you mess with any wires near the ECU? Is the throttle body harness disconnected?
