Brake Project Finally Completed
Old Sep 3, 2007 | 08:45 PM
MercedesFTW's Avatar
Cee Fiddy Five
u can re-paint your rear calipers and put a Benz sticker on it, if u want to just go for looks.
Ah, I don't actually care about the calipers, I want the rear discs to match the fronts...they look so mundane and un-AMG worthy!
Old Sep 3, 2007 | 09:59 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Wow.
Are those the rotors from Evosport?
Guess you had to remove those weights!
Old Sep 3, 2007 | 10:14 PM
Harry Madan's Avatar
03' E39 M5, 10' CLS63 AMG
Originally Posted by C230 Sport Coup
Wow.
no these are all factory benz parts, i got them from sunil.
what weights are u referring too
Old Sep 3, 2007 | 10:44 PM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
looks phat, good job!
Old Sep 4, 2007 | 06:48 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by Harry Madan
LOL, ya i know about time those got put on. i dont know if i want to go with coil-overs it has not been a very persuasive argument. so i have not really been sold on them yet. but we will see what happens, i dont want to deal with rubbing and bottoming out.
drive someone else's C32 with suspension upgrades and you'll know how ****ty the C32 handles on the stock North American suspension is. Or just drive a C55 and see how it handles. retuned spring rate and damper rate of the C55 made a whole lot of difference.
Old Sep 4, 2007 | 11:46 AM
so would a C55 stock suspension make that much of a difference on a C32, i have a friend who is up grading this stock C55 suspension to some coil overs so i can possibly buy his setup? do u think it would be worth it?
Old Sep 4, 2007 | 05:58 PM
  #32
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
it would make some what of a difference since the C55 suspension is firmer and stiffer, but it depends on how much he want to offer them to you.
even by just changing the springs to H&R, Eibach, or RENNtech the understeering characteristic will be a lot improved.
Old Sep 4, 2007 | 06:01 PM
  #33
changing the springs will that also drop the hight of the car?
Old Sep 4, 2007 | 06:49 PM
  #34
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
yes.
Old Sep 4, 2007 | 07:14 PM
  #35
Vomit's Avatar
2002 C32 Black/Charcoal
there is no way that a 17" wheel will clear those brakes, i have 18" on my car and there is like a paper line between the caliper and wheel. if ur wheels balance weights are off the edge the off the wheel the caliper will spit them out. u need a min 18" wheel to clear those calipers.
they are lighter then current C32/C55 bake setup for sure. i weight my caliper before and posted the results on this form u can find the post and then u can check the weight of ur current brakes and compare it. i'm sure they are lighter then the current C32/C55 setup.
this setup is really $$$ at the dealer, but i got them from Sunil. for around $4500 i think.
Really, really nice.
Given the paper-thin space between the calipers and the wheel, is there any concern about heat expansion of the calipers causing them to contact rim under heavy braking?
Old Sep 4, 2007 | 08:37 PM
  #36
Nop, i have tried semi hard braking there is no problems at all. i have not had them hit the rim at all and dont expect them to hit.
Old Sep 5, 2007 | 04:16 AM
  #37
m.e.g.'s Avatar
03 CLK55 AMG
Finally the CLK 63 brake project on my C32 is finished.
Harry, CONGRATS on the new brakes, they look great! I am waiting the arrival of the same setup for my 03CLK55. You posted some great installation photos of your setup. Could you post a few shots detailing the back of both (the front and rear rotor and caliper)? How did you address the rear brake shield? Did you trim it or replace it? Since I will have to address the same problem when I install the rear calipers, I would like to see how you dealt with this issue. Thanks
Old Sep 5, 2007 | 12:11 PM
  #38
JDC55's Avatar
Originally Posted by RumbleUK
Quick question whats the best way to install drilled slotted rotors in terms of position/angle of the holes slots eg
<--- Rear of car \`. O`.\ Front of car --->
<--- Rear of car /.' O .' / Front of car --->
I personally think the second one because it pushes debris eg brake dust away from the rotor outwards whereas the first pushes it inward to the centre of the rotor.
If that makes sense!?
you can only install the AMG rotors one way as they are not slotted separately for the left and right. So on one side the slot will be forward and the other side will be backwards.
Old Sep 5, 2007 | 01:15 PM
  #39
sure i can take some more pic and post them up, but for the most part i had to use the stock bolts to bolt on the rear calipers because the bolts i got with the new setup did not even fit the caliper leave alone the car, for the rear heat shield i just cut enough of an opening to fit the calipers and the heat shield has to be pushed back a little bit u dont need to take it off just bend it back a little bit so that rotors dont rub while they spin.
Old Sep 5, 2007 | 01:25 PM
  #40
Some more photos for the rear brake setup
As u can see the rear brake shield has been cut to fit the caliper.
Old Sep 5, 2007 | 01:26 PM
  #41
Old Sep 5, 2007 | 01:51 PM
  #42
drexappeal's Avatar
Super Moderator Alumni
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Hmmm...maybe I'll have to do this sooner than later...
Old Sep 5, 2007 | 01:52 PM
  #43
14cue's Avatar
05 C55
i had the honor to see these in person...needless to say, they gave me a hard on.
Downright sexy.
Old Sep 5, 2007 | 03:36 PM
  #44
drexappeal's Avatar
Harry, did you replace the lines with Stainless Steel? I'm curious, with these brakes, if the stainless steel lines for the w203 are cross-compatible.
Old Sep 5, 2007 | 04:47 PM
  #45
i dont have the stainless steel lines, but everything was a direct bolt on. i had to do no modifications other then cutting the rear brake shield. so i'm sure if u have them working on the w203 now u should have no problems putting them on this setup
Old Sep 5, 2007 | 04:48 PM
  #46
Downright sexy.
thx man, i really want a pic of these bad boys at full speed and see how they look through my wheels.
Old Sep 6, 2007 | 02:28 AM
  #47
JDC55's Avatar
Soon to be doing the same on my car but with red calipers and Brembo race logos
Old Sep 6, 2007 | 02:09 PM
  #48
ur going to buy the brembo GT kit then?
Old Sep 6, 2007 | 02:10 PM
  #49
drexappeal's Avatar
OMG, the Brembo GT kit is a lot more expensive. Fronts are more expensive than this whole kit! Well, if we're referring to the 6 piston caliper Brembo GT's.
Old Sep 6, 2007 | 02:20 PM
  #50
m3_eater's Avatar
WOW...pure sex.
