Gas light, how many gallons left?
When I'm low on gas ( below 1/4 ) I switch screen to range.
And must say it is quite accurate.
Few weeks ago I was in a hurry and low on gas I made it to the pump with range showing 3 miles, I filled her up w/ 15.4 gal.
Seems like no place for error
I get around 10-11mpg in the city and 21-22 on hwy.
And yes I'm wearing lead shoes- prescribed by dr
At Beaverun, I averaged 7.2
My stang on this track was about 4.0
Not bad for doing 125
See yeah
Oh yeah, Lifetime, I have 17.2 for 19,000 miles
This has been discussed to death . . .
sprintbooster which cost like $30-40 bucks to make in China that you guys are paying $250-300 for is a "relay" for the throttle position sensor which is on the gas pedal. It modifies the signal that goes to the ECU telling the throttle to keep it open at a bigger angle therefore the quicker response. The "only" reason that you are getting better response is because instead of waiting for the throttle to open at the normal angle, the SB is modifying the signal to keep the throttle open at a bigger angle.
if your pedal's pressed fully and your throttle body's not opening all the way that means something's wrong with either your throttle position sensor at the gas pedal or something's wrong with your throttle body.
I haven't run out of gas since I had a VW squareback with a broken gas gauge.. that was almost 20 years ago.. lol my first German car..
when I said that the post he made doesn't make any sense is because he argue that the SB doesn't make the throttle opening at higher angle at all time which then in his own post in the second sentense said the opposite.
this is just an hypothesis based on what you explained, say there's 10 position on the TB. When you take your foot off the pedal it returns to Zero, with the SB when you first step on the gas it tells the throttle instead of starting from 1...it quickly opens to 2. BUT without the sprint booster you can achieve the same by stepping on the gas pedal a little more. it would do the same thing, so there's the question why sprint booster?
other than keeping the throttle opening at high position at any time other than maybe just idle I really don't see how else you can achieve quicker throttle response as the claimed. I was just talking about the throttle response at idle.
Yes, you could make the car behave similarly by slamming the pedal down every time you wanted to just open up the throttle a little. That means if you didn't want full throttle, but wanted the better response, you would have to slam the pedal all the way down, then quickly return to part throttle. Doing that every time would be annoying and wouldn't feel right.
