2005 C55 AMG F1 Style paddle shifters
The guy in the video is super annoying, but just bear with it long enough to see the inside cab shots when he's shifting... you'll notice the shifters...
From about 1min30seconds on into the video, you can see them (tried it a few ways):
http://youtube.com/watch?v=w9hdwC5h8VY
https://mbworld.org/forums/c32-amg-c55-amg-w203/183031-pics-paddles-installed-05-c55.html
I'll probably do this to mine soon.
Roger
1. looks like there's the MBZ part you can order with the paddles, wiring, etc... but you have to drill in to mount....
2. Then I saw a member was having some custom paddles made this past April that had no wiring required and a 20 min install.. thread here: https://mbworld.org/forums/showthrea...hlight=PADDLES
3. Either way, what are the folks opinion who have either set installed?? I've read they're not great unless you have an M1 or M2 flash done... I'm assuming this is a shift program??
Feedback would be great guys, thanks! I'm trying to get it more to the feel of what the E46 M3 with SMG felt like...
I know the C55 wouldn't be as fast in shifting... but someone above wrote you can "train" the car to shift fast... please clarify...
Not sure how you mean that they get in the way, they are tucked behind the wheel just like the later cars that have them OE. You have a greater area to grab for a shift. The buttons are small and have a weak detent feel and it's too easy to accidentally cause a shift. It's all a matter of preference, and this is just another perspective.
The link to the asian made copies is interesting, but tough to determine if anything really materialized. They are much more expensive at more than twice the cost. My concern would be that the snap fit of re-using the button housing isn't enough to hold the paddle securely. I'm not sure that the switch feel would be improved as that is provided by the internal button switch which would be re-used.
While I cannot comment on autocrossing, on the track I do use the paddles but S works just fine as well. The main advantage for using the paddles in M mode of courrse- is engine braking which S doesn't really do as well as selecting the engine RPM a bit more. If you heal and toe when downshifting- you can use it effectively, but then of course you will get pissed off by the delay of the up shift... so you have to shift in advance unless you have m1 flash
Anyone who asks me about that don't ask do a search-
