I need a
Location: dayton ohio hopefully it will be some place warm and sunny when i finish med school
1 Post
2002 C32 AMG silver & 2003 Lancer Evolution 8 black very moded
I need a
MB part number for the i/c pump...
i got the ford #'s but i might be able to get an MB OEM for the same cost and the dealer wont give out the number to me
C32, Cobra, 700hp Vespa
I wouldn't bother with either. I would go with the Johnson CM30 pump. You can get it for $125 shipped. Vadim did a nice post about it.
CM30P7-1 pump [a.k.a. 10-24504-03] is $125 for the 12 Volt pump
http://autoperformanceengineering.com/html/jabsco.html
1 Post
thanks... but is it the same wire set up? and could i use or get a plug adapter for a plug and play set up? or do i have to cut and splice
1 Post
on the Johnson pump is the install still the same...? do i need to pull off the inlet housing like on the ford pump?
C32 AMG
To answer your initial question, the number off the Bosch pump is - PCA 12V 0-392-022-002. I just picked up a spare and that is right off the label...
Search is your friend
https://mbworld.org/forums/c32-amg-c55-amg-w203/206555-replacing-bosch-ic-pump-johnson-c030.html
Its a straight replacement.
1 Post
everytime i did a search it just came back to the ford i/c pump... but i could have been lazy and just didn't try hard enough... but thanks for the info
