Track results K&N, GREENS, STOCK FILTERS!
on 1st run on Jerry's car and I think about 13.76
on Waynes's E55 W211. So he did get in alot of practice I managed a 13.51 myself as personal best on my C32
If you want to know my preferance well I personaly like the Greens better. They seem to be felt more when you step on it while the K&N shows better after 330' of the results on the slip.
Any different in MPG too? I would think there should be a slight gain.
I was hoping that would increase but it doesn't my car is driven fairly normal most of the time and I get an average 16mpg on the streets and like 22mpg on the expressways
The LSD will make a difference ask a few members here like JGSX and they will confirm. Plus think why is it that the STI and EVO do so well of the line its cause more drive wheels so if the C32 uses one wheel mostly then the results should be better with two right?
Well reread your question and yes the only variable is the filters.
I dunno maybe my logic is off.
Do you have any pics of the different filters?
Dirty K&N filters got me like 275hp
to the rear wheels on a colder day by like 8-10 degrees.
So, if a stronger bone-stock C32 can run 13.5s, and yours ran 13.9, are you saying that you unfortunately ended up with one of the weaker stock C32s, and it took aftermarket plugs, wires, filters, and LSD to just level the playing field with a stronger stock C32?
The best way to test if it really does have a limited slip is to put the car in Dyno Mode. This compeltely disables the electronic "limited slip". If you can still burn both tires from a stop then you probably do have the aftermarket LSD. If you haven't done this, then my guess is you don't have one.
Its unbelievable how some people react here but once home I shall respond with a proper responce ok.
I think it sucks that there's so much variation in stock C32s power output, but I guess when you look at the forced-induction design of our cars, differences are probably inevitable.
I couldn't figure out if you were trying to say "yeah, unfortunately I seem to have one of the weaker ones, because after upgraded filters, plugs, wires, SL55 splitter, sprintbooster, and a LSD, I'm able to run 13.43 - and stronger bone-stock C32s run 13.5 right off the bat" - your post seemed to suggest that IMHO.
Though, this thread convinced me to seriously look at K&N or Greens.
I appreciated your info AND TIME as well. It backed up what my G-tech recorded, and what I have know for years with other cars.
THANKS for the GREAT work
See yeah my friend
In all I am very happy with my cars' results.
There are always doubters everywhere you go so believe me when I say I will not let anything or anyone deter me from posting things I feel is good for our forum to know.
be safe
