W203 C32 fuse chart?
Old Oct 30, 2007 | 03:01 PM
neihouma's Avatar
02 C32 AMG sold!
for the life of me I can't find mine, and last time I saw it
I changed my stock Bosch intercooler pump to the Ford SVT
Lightning pump. NOW I'm changing to the Johnson pump and
I want to make sure the fuse for the pump is in working order.
Any of you fine chaps have the chart handy? My email is
neihouma@gmail.com if you can kindly scan it or snap a
picture of it.
Thanks!
Rey
Old Oct 30, 2007 | 09:04 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Email sent. If you didn't receive it, let me know and I'll post it here.
Old Oct 30, 2007 | 09:09 PM
Eurocharged Rick's Avatar
SPONSOR
email sent...
Old Oct 30, 2007 | 10:15 PM
neihouma's Avatar
02 C32 AMG sold!
Thank you splinter & Erick! Got your email guys! Thanks!
Old Oct 30, 2007 | 10:16 PM
SPONSOR
no worries, sorry it took me so long!
Old Apr 1, 2008 | 02:45 PM
WM_C32's Avatar
Hi,
Can I get a copy of the fuse chart? My email is wm512@hotmail.com.
Thanks.
Old Apr 1, 2008 | 02:53 PM
sales@eurocharged.com's Avatar
SPONSOR
C63S
Please post a copy of the fuse chart for everyone.
Old Apr 1, 2008 | 04:53 PM
boohooramblers's Avatar
Not an AMG :(
Fuses and relay chart in left engine compartment
A pdf file of the Fuses / Relays in the left engine compartment. (file is from the W203 STAR DVD, although found on the web)
Old Apr 1, 2008 | 05:00 PM
Not an AMG :(
Fuses and relays in the REAR
A pdf file of the Fuses / Relays in the REAR compartment. (file is from the W203 STAR DVD, although found on the web)
File Type: pdf
Old Apr 1, 2008 | 05:01 PM
Not an AMG :(
interior fuses on the Driver's side
A pdf file of the interior fuses on the driver's side. (file is from the W203 STAR DVD, although found on the web)
File Type: pdf
Old Apr 1, 2008 | 05:04 PM
Not an AMG :(
Relays in front left engine
A pdf file of the Relays in the front left engine compartment. (file is from the W203 STAR DVD, although found on the web)
File Type: pdf
Old Apr 1, 2008 | 05:05 PM
Not an AMG :(
Relays in rear
A pdf file of the Relays in the REAR compartment. (file is from the W203 STAR DVD, although found on the web)
File Type: pdf
Old Apr 1, 2008 | 06:00 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
boohooramblers you rule man....working on troubleshooting a short issue and this helps tremendously!
Old Apr 1, 2008 | 10:57 PM
splinter's Avatar
Super Moderator
+1
boohooramblers is a veritable cornucopia of excellent intel for our forum. Thanks!
Old Apr 2, 2008 | 01:34 AM
c32used's Avatar
LET C32 2002
You are a great member to this forum...
Old Apr 2, 2008 | 01:43 AM
Not an AMG :(
Thanks guys! Just givin' back what I get in return from this forum!
Old Apr 2, 2008 | 01:52 AM
e1000's Avatar
a quarter mile at a time
you're a gentleman and a scholar.
Old May 11, 2008 | 05:49 PM
casper_c230's Avatar
Mercedes Benz c230
Even with your spoon feeding, I can't find the fuse for the license plate light. Any thoughts?
Old May 11, 2008 | 08:15 PM
edtv82's Avatar
From: dayton ohio hopefully it will be some place warm and sunny when i finish med school
2002 C32 AMG silver & 2003 Lancer Evolution 8 black very moded
if you open the drive side door.... on the side of the dash there is a panel that can be pulled out and there is a fuse chart folded up in there... has the charts for under the hood in the car and in the trunk
Old May 15, 2008 | 01:57 PM
Mercedes Benz c230
Wow, thnx! I'll check it out today.
Old Oct 18, 2008 | 04:08 PM
c32jet's Avatar
02 C32 - More Fuse info - door lock question - alarm question
More Fuse info from my 02 C32. Trying to figure out why my alarm horn wont turn off - had to take out the #8 fuse to get it to quit.
Wondering if this has anything to do with why my door locks on the driver side door is not working (or intermittent at best). Have to walk around to the passenger door to lock/unlock.
Attached Thumbnails W203 C32 fuse chart?-fuse-1-resize.jpg   W203 C32 fuse chart?-fuse-2-resize.jpg
Old Oct 30, 2008 | 02:50 AM
C32-4ME's Avatar
02' C32 - 07' H2 - 07' BMW K1200R
Thank You!!!!
Old Oct 30, 2008 | 09:25 AM
e1000's Avatar
there is no fuse for the license plate lights
Old Feb 15, 2009 | 12:46 PM
c32jet's Avatar
Alarm - How to make it stop
Solution: I finally got my alarm and doors working normally.
Not sure if it was the sequence or what or perhaps I had not tried the steps fully. Here are the steps to fix my door lock (drivers side would not work with key fob) and to get my alarm to shut off.
Starting with #8 fuse out...
1) Use the metal key in your key fob to open and lock the driver side door
2) Put #8 fuse in - alarm goes off - this was my problem all along - never knew why it went off or how to get it to turn off again. I did this in my closed garage and the thing nearly deafened me with the high pitch sqeal - put on some ear protection.
3) use the key fob to lock and unlock the car doors - alarm will stop.
I know this sounds simple, but it took me a while researching here on the forum and many times playing with that fuse to figure it out.
Old Feb 15, 2009 | 11:21 PM
neihouma's Avatar
02 C32 AMG sold!
Found my fuse chart, did a full scan, so you can print it out if you like. If
you want the full version email me neihouma@gmail.com and I'll send it.
Attached Thumbnails W203 C32 fuse chart?-front.jpg   W203 C32 fuse chart?-back.jpg
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
