How to totally disable ESP
Old 11-02-2007, 06:47 PM
bud4ya's Avatar
2003 C32 AMG, 2003 E39 M5
It sounds like when you shut off ESP the system still partly functions. I think it is the brakes. I know in my BMW when I turned of my DCS it would still apply brakes if it sensed the tires loosing grip. By holding the button in for 10 sec's it would total disable everything.
Will that work on the C32 also?
Old 11-02-2007, 07:26 PM
amgmark's Avatar
ML63
do a search for dyno mode.. that might be what you are looking for. I thought just pushing the esp button was typically sufficient for me..
Old 11-02-2007, 07:31 PM
bud4ya's Avatar
Even with ESP shut off when you mash the gas you can still feel some system working. Almost like when the tires loose tracations the brakes are being applied.
Maybe the dyno mod will cut both the trac and the braking.
Old 11-02-2007, 07:45 PM
amgmark's Avatar
ML63
Look right above your post.. its a sticky thread.. LOL
https://mbworld.org/forums/c32-amg-c55-amg-w203/201412-dyno-mode.html
Old 11-02-2007, 07:48 PM
c32used's Avatar
LET C32 2002
That will shut it of but I just hit ESP off to do my drag runs it was sufficient.
Old 11-02-2007, 08:42 PM
e1000's Avatar
a quarter mile at a time
dyno mode disables all electronic aids including ESP, ABS, and BAS.
Old 11-02-2007, 08:50 PM
1FSTAMG's Avatar
C32 AMG - RIP :(
and it enables the One Wheel Peel
Old 11-03-2007, 09:19 AM
SPONSOR
Eurocharged Rick's Avatar
yup, you will have worse wheel spin with ESP completely disabled...that is why i entitled that sticky thead DYNO MODE! it should only be used on the dyno...
Old 11-03-2007, 11:05 AM
c32used's Avatar
LET C32 2002
Question
Will this cause a LSD to not spin both tires?
Old 11-03-2007, 11:09 AM
SPONSOR
LSD should be fine, although if you have an LSD, it will make the Dyno mode pretty pointless at the drag stip...
Old 11-03-2007, 11:15 AM
c32used's Avatar
LET C32 2002
Question
will this still cause LSD to only spin one tire when in dyno mode? If I use dyno mode will the LSD still spin both wheels?
Old 11-03-2007, 11:21 AM
SPONSOR
no, the LSD will spin both wheels, that is what it is designed to do...the ESP system on the C32 is designed to mimick a true LSD, which is why only one wheel spins when you put the car in dyno mode...
Old 11-03-2007, 12:32 PM
bud4ya's Avatar
I saw that right after I posted I will have to take a good read through it.
https://mbworld.org/forums/showthread.php?t=201412
Old 11-03-2007, 12:40 PM
bud4ya's Avatar
Just to re cap if you put the car in Dyno Mode and you drive it hard from a stop you will get one wheel spinning and the other systems like ABS and BAS will not engage.
Now if you have LSD and put it in Dyno mode you will still get both wheels spinning and other systems are shut off.
Now with ESP off you will get LSD but the BAS and ABS will still engage when the tires loss traction.
So if you want true LSD at all times and not other systems kicking in to slow you down you need to do the LSD upgrade and put the car in Dyno mode.
These are more questions than statements. Correct me if I am wrong I do not want to lead anyone in the wrong direction since I am new here.
Old 11-03-2007, 01:27 PM
neihouma's Avatar
02 C32 AMG sold!
Disabling the ESP isn't gonna make your car run any faster, I've tried this
at the drag strip already. Look at car#5140
Old 11-03-2007, 01:51 PM
1FSTAMG's Avatar
C32 AMG - RIP :(
An LSD will spin both tires in dyno mode. Actually there IS a benefit to racing with an LSD in dyno mode. It will allow you to put all the power down without any intervention from the ESP.
that is....IF you have an LSD, which I still think you don't.
Old 11-03-2007, 01:52 PM
1FSTAMG's Avatar
C32 AMG - RIP :(
Bingo. Exactly correct.
Old 11-03-2007, 01:54 PM
1FSTAMG's Avatar
C32 AMG - RIP :(
Do you have an LSD? If you did, it WOULD make you faster at the track. No ESP to apply the brakes or torque managment and no one wheel peel. Just all the power applied to both wheels.
Old 11-03-2007, 03:41 PM
dkflipse's Avatar
C32 AMG
Or you could just run in dyno mode and save yourself $3,000 fro the LSD??
Old 11-03-2007, 04:09 PM
e1000's Avatar
uh no. nothing replaces a mechanical LSD. Dyno mode is simply a way to disable all electronic aids, which is only good for 2 things. Making big clouds of smoke and if you want to actually put your car on a dyno.
Old 11-03-2007, 09:51 PM
c32used's Avatar
LET C32 2002
Ok after trying dyno mode I came to conclusion based on result on this method that I DON'T HAVE LSD installed cause one wheel the passenger rear spinned solo.
Old 11-03-2007, 10:04 PM
SPONSOR
just to clarify one point here...if you have a LSD with crappy tires in DYNO MODE, you will still not be able to put the power down completely and it will be a complete waste of money...
i don't have an LSD and i run Nitto INVO's (which are my street tires) at the track with 25psi in the tires and i never spin...it hooks great out of the hole even stepping on the gas while holding the brake at 1500rpm's from a dead stop...i am also puttin down 346 rwtq, which is more than most C32's on this board...torque is what causes the wheel spin off the line...
my point: spend the money on good tires before you drop $2-3k on a LSD...
Old 11-03-2007, 10:20 PM
1FSTAMG's Avatar
C32 AMG - RIP :(
A perfect reason to upgrade!
Old 11-03-2007, 11:58 PM
jgsx's Avatar
04 C32
I don't see how you guys get by without an LSD. Sure, tires made a HUGE difference, but even with nice rubber, without an LSD I was not able to lay my power down below 30mph. ESP would take away the fun EVERY time. I usually mash the pedal from a slow roll, and that just wasn't going to happen with an open diff.
Old 11-04-2007, 12:50 PM
1FSTAMG's Avatar
C32 AMG - RIP :(
i'm broke. otherwise I'd have a pulley, tune, headers and LSD on this thing.
Quick Reply: How to totally disable ESP
