Car pulls to the right
Old Nov 4, 2007 | 06:59 PM
bud4ya's Avatar
2003 C32 AMG, 2003 E39 M5
When I am driving the car tends to pull to the right. If I let my hands up off the steering wheel the car pulls immeaditely to the right.
Does it sound like I need a front end alignment?
Old Nov 4, 2007 | 07:02 PM
rlee02135's Avatar
2004 C32 ///AMG
yep, probably needs an alignment. any shaking in the steering wheel at high speeds?
Old Nov 4, 2007 | 07:09 PM
bud4ya's Avatar
Ya a little but not real bad
Old Nov 4, 2007 | 08:12 PM
D_Star's Avatar
05 CLK55
mines like that too, but you don't need to worry too much. IMO, this is only caused by slightly slanted road surface that can not be judged by our eyes.
Old Nov 4, 2007 | 09:02 PM
gkstar's Avatar
C32 AMG - in Pewter
Definitely check you tire pressure (32 front, 35 rear). Mine was pulling quite a bit until I corrected pressure. With cooler weather pressure drops, so this correction is required. On my other car, there is not much difference if pressure drops, perhaps it has to do with the low profile tires.
If that does not help, do wheel alignment.
I also used to have a Honda that went into an accident and I had tires changed at the time of repair. Car started to pull right, nothing helped, including alignment. I thought it is from the accident. Then I changed tires a few years later - pull was gone completely. So tires were crappy for sure.
Old Nov 4, 2007 | 09:34 PM
blown93lx's Avatar
2007 C350 6M
As stated, check the tire pressures... I went to the dealer with the same problem on a BRAND NEW C-350 and they told me the alignment was fine....
I ended up driving on some newly paved roads and realized it was just the crown in the road...
If the stealer will do an alignemnt check for free, I would have it done.
Good luck
Old Nov 5, 2007 | 07:47 AM
bud4ya's Avatar
Thanks I will check the pressure. I was going to say this morning it felt like the front left tire was loose. When I got out I looked at the tire and it appears to be low. I will fill today and post back.
Old Nov 5, 2007 | 01:22 PM
RW C55's Avatar
'10 E63 Obsidiant Black; '06 R350 Alabaster White; 05 C55 Obsidiant Black (sold)
My steering wheel is shaking at high speeds.. i'v done alignment already but still no fix.
what should i do?
Old Nov 5, 2007 | 02:47 PM
slowrey's Avatar
2006 Mercedes C55 AMG
Make sure that your wheels and tires are balanced. That would be my next step. You never know when a weight fell off your wheel.
Old Nov 5, 2007 | 02:59 PM
c32used's Avatar
LET C32 2002
what should i do?
Hey I been told if it starts anywhere near 60 M.P.H. and up thats its your wheel balance. So check or have checked your rims for possible damage but for sure get your wheels balanced...maybe your tires are close to requiring to be changed so ask the shop to check the life of your tire before a balance cause with new tires a balance would get done anyways.
Old Nov 5, 2007 | 03:58 PM
RW C55's Avatar
Thanks for the fast replies, you guys are awsome
i'll definitely go do a wheel balance sometimes this week.
Old Nov 5, 2007 | 06:45 PM
bud4ya's Avatar
tires where low. I added 32 front 35 rear. It helped but did not take it away totally. I will have the dealer take a look and see what they think?
Old Nov 5, 2007 | 08:01 PM
blown93lx's Avatar
2007 C350 6M
Good luck
Also make sure the car isn't just following the crown in the road.. Try it in multiple areas to make sure its pulling.....
I argued and argued with the stealer, i really did think it was pulling.. Then after they showed me it was in spec, I checked it on some different roads and realized our FL roads suck!
Old Nov 5, 2007 | 08:50 PM
bud4ya's Avatar
I will try it on a couple different roads the roads are pretty crowned here in NH.
Originally Posted by blown93lx
Good luck
Old Nov 5, 2007 | 09:31 PM
roosn's Avatar
2014 S550, 2010 E350
Mercedes should not pull on crowned roads. Thats what Model A's did. The cars of today are better than that. Tell your dealer you want a new car to drive like one. Not one 70 years old.
Old Nov 5, 2007 | 09:39 PM
blown93lx's Avatar
2007 C350 6M
Okay I told my dealer and he said to stop reading stuff on MBworld
