Questions about bi-xenon's help!!!!
C32 AMG
According to a fourm member his bi-xenon's auto level was fixed after resetting done by the dealer,
First of all i switched from xenon to bi-xenon for my C32
and my ballast died a while ago. so i switched ballast for one headlight.
here's my question.
will i need to go to the dealer to reset because only the side i replaced the ballast does not self-level?
The right side works perfectly.
Thanks in advance for the inputs!!
here's my question.
Location: dayton ohio hopefully it will be some place warm and sunny when i finish med school
1 Post
2002 C32 AMG silver & 2003 Lancer Evolution 8 black very moded
thats a good question... did you buy DEPO's or OEM bi-xenons? im assuming OEM's but the auto level feature.... i would say just either un hook your batter for about 30Minutes and the ECU will reset... but that might not be a ECU issue either... umm take a look at your other ballast and see if there was anything different that the one you have on now?
Super Moderator Alumni
It is in the manual but here it is: put each window down, pull and hold each button for about 2-3 seconds. Done. Do the same for the sunroof. This will re-initiate the one-touch up and down.
