c class seat modules compatible with c32?
Old 01-16-2008, 09:57 AM
c32used's Avatar
LET C32 2002
Question
Originally Posted by TemjinX2
i'm glad i was able to contribute as a new member.
I wished more people did Diy's on the forums.
It would definately help mercedes newbies like me.
If you don't mind I am adding it to a newbie how to I started ok?
Old 01-16-2008, 05:47 PM
TopGun32's Avatar
another solved problem!
I'll start searching for my parts in the next few weeks..!
Old 01-16-2008, 07:59 PM
AWDman's Avatar
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
excellent! thanks guys.
Old 01-18-2008, 12:03 PM
johndddd's Avatar
2023 C300w/AMG package
I have a pair of NEW seat modules for sale in the classified section.
Old 03-13-2008, 04:30 PM
TopGun32's Avatar
I'm on the hunt to get these modules....
I almost found them with a member selling E55 parts, but the connectors were all different.
I'm thinking that the revised W211 part has changed over the years.
Old 03-13-2008, 09:05 PM
nick 55's Avatar
GL550, C55, 335i Coupe, vintage Mustang
Originally Posted by c32used
Welcome to MB!
Toyota/Lexus will treat you way better.
Unless you use me right?
Old 03-13-2008, 09:16 PM
  #32
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
are the part numbers the same?
i also heard that the w211 seat modules were the same as the w203 as well. But i dont think anyone's confirmed.
Old 03-13-2008, 11:41 PM
  #33
TopGun32's Avatar
i'm not sure..
the ones i found and I receive the pictures from the seller did not look the same connectors and I told him that I would keep looking.
I'm thinking the W211 were changed in 2007 or maybe 2006 like the one you found in your car.
I'll post pictures tomorrow of the ones I was being offered.
Old 03-25-2008, 08:58 PM
  #34
TemjinX2's Avatar
ok just wanted to give everyone a update. one of the modules i bought recently started giving me the same problem as before. i had to use my spare.
i'm convinced that all the c-class modules are junk. I would save and just buy the revised modules from the w211.
Old 03-26-2008, 01:46 PM
  #35
TopGun32's Avatar
yup.. that's what I figured too.
i'm not sure if all W211 modules work.
I'll check my 2003 E55 tonight to make sure. I'm thinking only 2006+ newer W211 work.
Why?
Recently another member was parting out with their E55 and the modules he was offering had very different connections. The pictures were not on a good angle, so I decided to pass.
Old 03-27-2008, 11:03 PM
  #36
TopGun32's Avatar
just checked my E55.
the seat module connections are the same as my C32
2003 will work.
I wonder if it depends on the type of seats.. I have dynamic seats.
Old 04-29-2008, 12:57 AM
  #37
aolsen's Avatar
2013 S550, CLS500, ‘03 SL500, “92 190E Sportline
2003 will work.
Is the c32 module the same as for a C230? I don't want to buy a defective one lol...I can't find any online...
Old 04-29-2008, 01:05 AM
  #38
Gramma_Benz's Avatar
2002 C32, 2012 S550
Mine didn't cost that much...
I don't know where my mechanic got mine, but I had the same issue with my car and finally diagnosed the problem via the great information on the boards here.
He managed to replace it parts and labor for about $130 total for one seat module.
Can't believe that one so called "Mercedes Specialist" told me that I needed to replace my whole command system. Then I told him what I had read on the forums about the seat module and it worked. I told him to just leave it disconnected and I brought it to another mechanic.
Regardless, maybe there are other aftermarket manufacturers who make compatible parts?
Old 04-29-2008, 01:12 AM
  #39
c32used's Avatar
LET C32 2002
I have yet to read of an aftermarket replacement...
Old 04-29-2008, 01:29 AM
  #40
TemjinX2's Avatar
yes, the one i bought was from a c350. It worked for a couple of months and then had the same problem. the new replacement part is the same from a w211. The w211 seat module doesn't seem to have the same problem.
Old 04-29-2008, 01:48 AM
  #41
aolsen's Avatar
Good to know! I'll be on the lookout for a W211 seat module...I've had a permanent "gangsta lean" since November lol... Since the seat isn't in an awkward, uncomfortable position, I haven't fixed it yet...
Old 08-28-2008, 10:14 AM
  #42
savvy75's Avatar
2008 BMW 135i
FOLLOWUP...
Any news on the W211 part number?
Any news on the seat module schematic and/or fix?
(I would think that there would be some way to disable that 30-min delayed power-off 'feature' and just have power to the seats when the key is in the ignition.)
The part numbers were different since there for a regular c-class model. But doesn't mean there different parts. Mercedes might of just given them different part numbers because there for different model cars even though its the same part, so they can charge more for the upper models.
I have no guarantee other then what the seller said and my paypal fraud protection since i bought them on ebay.
For a chance to have working modules for $50 each instead of the $200 a piece i figured it would be worth the risk.
There is a theory in the c-class forum that the reason it drains the battery is because the circuit in the module that tells the ecu to turn power off the seat after 30min becomes defective and never tells the ecu to turn off the power.
If its electronic like that..there's no real way to fix the problem...hence the dealer recommendation is a replacement rather then rebuild.
If someone would put up a schematic of the seat harness...i probably could've fixed the problem for $20.
I didn't feel like getting a volt meter and testing every single wire...so i went with this option.
Old 08-28-2008, 01:46 PM
  #43
savvy75's Avatar
2008 BMW 135i
Post UPDATE - Seat Control Module part numbers...
//AMG C32 replacement Seat Control Module part numbers
(I asked for 2002 C32)
A211 870 47 26 (driver side) - $370
A211 870 46 26 (passenger side) - $370
(as per MB of Naperville 2008-08-28)
Anyone know where we can find the seat control module schematic?
Old 08-28-2008, 02:15 PM
  #44
savvy75's Avatar
2008 BMW 135i
Thumbs up EVEN BETTER...
BONUS:
As per RBrenton's - MBWORLD OEM New Parts connection, the replacement modules cost only $296.00 each (plus shipping, paypal, etc..)
PRICE SHEET:
http://www.keepandshare.com/doc/view.php?id=631973&da=y
Old 08-29-2008, 05:15 AM
  #45
TemjinX2's Avatar
i kind put it on the back burner since i would just move the seat to the desire position and unplug it. I have a feeling though the + is the brown wire that connects to the front harness of the seat control module. I dont have a volt meter to confirm. Given there's only two wires, you have a 50 50 chance.
one you find the correct wire, you can hook it up to a relay and use the cig lighter as the trigger. This way the seat control module would only have power when the car is in the second acc position.
Old 09-23-2008, 10:30 PM
  #46
TemjinX2's Avatar
hi everyone, i got home early today and decided to see if i can fix the battery drain issue with a relay.
after some experimenting was able to do it.
Its basically a $20 fix...here's the link
https://mbworld.org/forums/showthrea...55#post3068555
Old 09-23-2008, 11:46 PM
  #47
c32used's Avatar
LET C32 2002
Old 10-29-2009, 09:10 AM
  #48
WaveyKat's Avatar
Something Slow
i have been having some Battery Drain Problems i think my seat Module is going bad i dont mind replacing them with the Newer Modules i have 2001 C320 With 2005 C55 AMG Seats and the Part Number for the C55 Module is 2038705026.. when i type this number in it shows as a part for Control module, e320,e320cdi,e350,e500,e55,cls500, cls55 amg, r350, r500 2006.. so am guessing this is the NEWER Modules that dont Drain the Battery...
can anyone help me on this?
Old 10-29-2009, 11:49 AM
  #49
TemjinX2's Avatar
the 211 is the new part number. the 203 is the old one and all of them are crap and all go bad eventually.
Old 10-29-2009, 01:00 PM
  #50
WaveyKat's Avatar
Something Slow
so even if i have the C55 Seats it doesnt Matter? if i get the 211 Part number?
Quick Reply: c class seat modules compatible with c32?
