Pulley after secondary Air Pump SW-Reflash
here is a post from the E55-Forum :
Has your car had the air pump recall done with the new flash software. If so, then what you are feeling is normal. Mercedes put a load limited in that dumps fuel and opens bypass valve so you can actually see less hp with the pulley than you would stock. The car will 'feel' faster (seat of the pants meter), but that's because it takes a second or two before the new software starts limiting power.
I have done the software reflash on my SLK32 by MB. Is this also a problem with SLK32 or C32 when you get a larger pulley?
Thanks!
Kind regards Bruno
Thanks!
Kind regards Bruno
https://mbworld.org/forums/c32-amg-c55-amg-w203/224731-secondary-air-injection-diagnosis-c32-amg.html
According to Power-Loss and problems to overwrite the the "After-reflash- lines" i can only find information about the E55K ? Has any C32/SLK32 -Driver experienced the same problems on his car?
Thanks.
Kind Regards
Bruno
