Secondary Air Injection Diagnosis C32 Amg
Does Any Body Know What This Fault Means? And Will It Effect The Car In Any Way?
SERVICE CAMPAIGN 2006030011
MODEL 170/199/203/211/215/219/220/230/463 AMG
MODEL YEAR 2002-2006
REPLACED SECONDARY AIR INJECTION PUMP RELAY
DC 59 950 01 7
FW PERFORMED CAMPAIGN 2006030011 COMPLETED REPLACEMENT OF RELAY AND PERFORM ME UPDATING PROGRAMING
FP-NUMBER 002-542-26-19-64
SECONDARY AIR PUMP (GETTING CHECK ENGINE LIGHT/ERROR CODE P0410)
PART#000-140-42-85 OR 0580000010
RELAY
PART#002-542-26-19
203-545-16-01(CONTROL UNIT)
The second one, they replace the air pump relay and reprogram the ECU to limit the time the air pump runs, so it will not fail as soon.
Do a search on recall or air pump. You will see lots of info on this.
The air pump helps the cats out by providing O2 to heat them up faster at start up.
I say do NOT let the dealer perform the ECU flash until you research this a little more. There is plenty of very useful threads in the E55 section of the forum about this topic. For now, just have the dealer fix the pump and the faulty relay relay switch but not to flash your ECU with the new software.
Here are some threads about the ECU re-flash, but if you do a search, you'll even find the discussion gets much deeper.....
https://mbworld.org/forums/w211-amg/153434-alert-hold-your-stock-ecu.html
https://mbworld.org/forums/w211-amg/157866-2003-e55-ecu-flash-another-mad-owner.html
https://mbworld.org/forums/w211-amg/163868-i-am-dissapointed-amg.html
https://mbworld.org/forums/w211-amg/163098-i-lost-70-rwhp-where.html
https://mbworld.org/forums/w211-amg/163617-dealer-ecu-reflash.html
https://mbworld.org/forums/w211-amg/166415-dyno-results-stock-vs-mb-recall-flash-vs-re-flash-renntech.html
https://mbworld.org/forums/showthread.php?t=153434
https://mbworld.org/forums/showthread.php?t=157866
https://mbworld.org/forums/showthread.php?t=163868
https://mbworld.org/forums/showthread.php?t=163098
https://mbworld.org/forums/showthread.php?t=163617
https://mbworld.org/forums/showthread.php?t=166415
but if you don't have a ECU flash and only bolt on mods.. you should be okay.
If you are stock.. you might see a bit different power delivery as on my C32.
As far as my E55.. got the recall last month.. and the engine feels better than before.
than again.. I only have bolt on mods and I'm pushing more PSI than stock.. maybe I dont notice the power difference as much.
