will Brabus monoblock v 19x9.5 and 19x10 fit c55?
2018 E63 AMG
I'm considering buying a used set from a guy locally and I'm wondering if these will fit the C55 and/or clear the calipers? They seem too wide...
if so, does anyone know what the biggest tire size is i could go on these?
35mm offset..
the other size i'm considering is the same wheels in 18x9.5, which i'm sure has a much better chance of fitting, but i still dont know if they'll clear the calipers
35mm offset..
2010 E350 SP / Honda Crosstour / prior vehicles - C32 modded / C300 modded / Lincoln LS modded
c55
i'm no expert but I beleive 165 30 19 is the widest rear tire you can go. I have 19's and kinda wish I went 18 for a bit better ride quality. Oh and if they are replica brabus wheels they are much heavier.
2018 E63 AMG
how wide are your 19's? what tire size do you have on yours? did you have to use any spacers?
