got declined for loan for C32, Here are pics of my credit score, any advice to fix?
To me, paying off half or all of your student loans is more about how you prioritize your money than about your credit. If you have enough income, once your collection account has been disputed, you shouldn't have any problems getting a loan for your car.
I understand that your overall utilization is 65%... but to be honest, it's not that bad.... couple of my credit cards have close to 90% utilization (0% interest and put the money to money market = free money
), yet my FICO score is still above 700. This is mainly due to my long (which you cannot control) and clean history (in addition to tons of available credit - I think around $300-400K total lines on credit cards alone, hence, low overall utilization).Refinancing won't hurt your credit other than additional inquiry posted to your credit report, which only gives temporary impact. Your score may not even be affected at all given additional accounts (which is good) and lower debt ratio that would offset the inquiry impact.
So another tip when you're ready to buy a car.... shop for loans at the same time... if possible, do all on the same day. Inquiries from the same industry (i.e. car loans) within a short time period (I think up to 1 week) will be deduped by credit bureaus at the end of the month... so you could put 10 inquiries on one day... and it will only hurt your credit report up to 1 month. The next month, they will be only 1 inquiry.
zoink has good points but even if he has 90% credit used up on 1 card, it's overall credit availability that's the key factor, not individual card usage. He's fine because he has high limits (in total).
Make sure all correspondence to credit reporting agencies are done via Return Receipt post (can't do it online since you need to send in proof of the invalid collection, do not rely on someone else to fix it for you). You need that green confirmation card to follow up on if nothing happens. 3 months is optimistic - they state it takes minimum 90 days to respond. Double it to 6 months (you will receive a copy of your new credit report once it is corrected, in the mail).
When you do dispute the collection, dispute anything else that is inaccurate on your report, get each credit report agency to fix everything. Itemize each correction in your letter. Keep copies of what you send out along with the return receipt card (and dates sent).
A collection is probably worth about 50 points. What's killing your score is credit utilization at 65%. Drop it to below 20%.
You seem very fixated on a car and less on solving your credit problems. Take this advice from a guy who had a FICO of 515, clear the student loan completely. There's no point in refinancing the loan if your credit score is still in the ****ter.
Next, clear the collection (pull a credit report from each agency, transunion, equifax, experian - ignore the 3-in-1 reports, pull each individual report, write a letter to dispute the collection and provide proof, you will receive an acknowledgment letter within a month and several more before it gets wiped out)
It takes time for your FICO to bounce back, many months. Check your scores every 3 months for changes.
Hard inquiries (credit check reports) like when applying for loans, do count. A few inquiries within a short time span that is obvious (car loan, mortgage) will be negligible but it doesn't mean that your score won't be reduced slightly (-10, 20 pts)
I'm not going to mince words here. What you think so far, isn't working. That's what got you into the credit mess you have now. Listen to the words of people who have been financially more successful (than you) and heed them.
The car will still be around. Insurance isn't the only thing to consider. Gas, upkeep and repairs (include extended warranty costs)
db2012
WHAT YOU REALLY NEED TO KNOW:
1. YOUR BALANCE SHOULD BE ZERO.
Your debt is over $11k when your balance should actually be $0. Do NOT keep a balance on your accounts. You should owe absolutely nothing at the end of each month. Pay off everything you owe each month.
2. HOW IS YOUR CREDIT SCORE CALCULATED?
Credit is reported based on a ratio between your credit limit and how much credit you actually use. If your credit is $5,000 per month, using $1k is better than using 2k. The closer you get to the maximum, the worse off you are. SOLUTION 1) Spend less 2) call your credit card comapany and ask them to raise your limit. By the way, do NOT cancel any of your credit cards. Doing so will also cancel good credit you may have accumilated.
3. WHEN PAY SOMETHING OFF VS. PAY IN MONTHLY INTALLMENTS:
For everything you buy excluding big ticket items like cars and houses, you should be able to pay in bulk. The only reason you should choose to pay in monthly installments is to increase your leverage.
The interest that you're paying should be LESS than the interest you are EARNING by NOT paying. If you can earn more on the money than the amount you owe, keep the money and make money. e.g. Let's say you're earning 8% on your money. Why pay off a 5.5% loan on the same amount if you can make the difference of 2.5%? If on the other hand, you're being charged 4% on something, while you're only earning 2% on the same amount, you're losing 2% every month. Got it?
4. YOU HAVE LOTS MORE TIME:
Look foward to the c32. No need to have it now. You already have a Mercedes. Keep your money, pay off debt and then improve your lifestyle if you have money left over.
5. GET YOUR PRIORITES STRAIGHT:
Pay yourself first. Declare a certain amount to transfer monthly from your checking to your savings account. Use whatever's left for your expenses. Don't do it backwards and gather up expenses and save what's left. You'll find you'll end up with nothing to save.
However, if you negotiate (and get it in writing) to pay and get them to remove it from the report, you'll be fine. Not supposed to work this way but you want it off your record, they want to get their money back, it works.
Good luck!
Also, keep in mind you'll need at least $2K/year to maintain the C32; it's an expensive toy going for cheap.
Try applying online at Capital One. My brother was in the market a few months ago and that's where he got the best rate.
Factor all that in your budget and list your priorities. Good luck.
*Random advice: you should save at least enough money to cover your operating cost for at least 4 months, also known as an Emergency Fund. Whatever the amount is, put it in a short term CD or MM.
As we all know, even once you've managed to buy a C32, the costs sure don't end there! They're very expensive to maintain (a spark plug change on one of these things is over $500) and they use a lot of premium gas at $3.50+ per gallon. Plus, C32s and C55s are depreciating fast. It's not like they're going to get more expensive any time soon. Wait a couple of years and a decent '04 C32 will be a $15k car.
If he feels the "need for speed" there are a lot of cheaper options out there to get him by for now. How about a $10-12k E36 M3?
There is Zero need to pay off that student loan, and in fact, it's actually better not to since you have short credit history, as it will establish longer payment history and more creditworthiness.
Get rid of that collection. Whether it's a real debt or not send a letter disputing it or call them and work out a deal to pay it conditioned only on removal from your credit report.
You must have really low income or something at least claimed as well to have such low credit offered. Any amount over 50% on cards brings your score down. Do all of those things and maybe apply for another card with a single digit interest rate, xfer the balance from the higher and you'll be better off interest wise as well as % of carrying on cards wise and you're fico will be better, or pay off the amount on cards to under 40% and you should be decent-
