IMPORTANT to C55 owners: Dont **** with ur button shifters!
Actually I found Kjb55's post and SPR states:
"YOu beat me to it. I just got done with mine at about noon today. It was the biggest pain in the *** I have ever done. I would not do it again honestly! They're wierd to get used to. I swear they grazed my leg when I was turning today. I have driven with them for about 1 hr. now and they're fine. I had to get used to the buttons though also. The feel is soo much better than the buttons but without the m1 program it's moot."
I based all comments off your original post. Simply because you could not complete the modifcaiton, it is no indication others should or cannot follow suit.
My issue simply laid with using the wrong bit and taking more time as it is what I had on hand, otherwise it IS simple and rather uneventful. I won't bother commenting further.
According to your comment previously quoted it wasn't easy. Thus instead of sharing tips and tricks with posters you attack them. Way to be a member of this board.
Thanks, Neal!
The reason I have no tolerance for your post is because you're making a big deal out of nothing and giving others misinformation.
What is the main problem that you're having? That you're too apprehensive about going too big and buggering the housing? Use a marker and outline it and then go less than the inner marks. This is half the reason I took so long becase I purposely didn't want to bugger it (using a sanding wheel which took 2x as long). I think my experience in head porting helped but if you read the original e55 post this was clearly stated.
BTW if you have already done some of the dremeling the OEM buttons might not even be retained properly as they pressure fit in there and so you might be forced to actually complete what you started-unless you use an epoxy or something.
If you want some help completing it I'll help you but don't scare others out of attempting it when it's not that big of a deal-
If you cant give suggestions to my problem i stated in the original post (to order a new set of button shifters), dont respond.
And whats wrong with letting the people whos attempting this mod know about this issue? They should be informed that if they accidently screw up the modification,(i.e. cutting too much of the housing), its not something that can be fixed easily.
Give him a break he's being nicer.
SPR i apologize for my childish behavior.
